Warning message
Issue while upgrading 6509 IOS software
Jul 8th, 2012
I have upgraded from s72033-adventerprisek9_wan-mz.122-33.SXH3a.bin to s72033-advipservicesk9_wan-mz.122-33.SXI7.bin.
the problem is:
1) when i do sh bootvar after reload then i se,
BOOT variable = sup-bootdisk:sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXH3a.bin,1; ---->  OLD IMAGE
2)  when i do sh version after reload then i see,
System image file is "sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI7.bin" ---->  NEW IMAGE
3) when i do power off and on then it goes to rommon mode
and then i have to configure:  boot bootdisk:sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI7.bin
but the situation is same. it shows old image in bootvar and new image in show version.  output is below.
again i configured boot system flash as below.
after saving configuration the show bootvar is,
BOOT variable = sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI7.bin,1;sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXH3a.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby not ready to show bootvar
then i reloaded and what the image in bootvar is only old image, and in show version is with new image.
i do not know what is happening.
boot config:-----
boot system flash sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI7.bin  ------> NEW IMAGE
boot system flash sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXH3a.bin -----> OLD IMAGE
    Supervisor Engine 720 (Active)         WS-SUP720-3B
   sup HW type------------ 5.6   8.5(2)       12.2(33)SXI7 Ok
output:
B3ECID1-S5#sh bootv
BOOT variable = sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXH3a.bin,1;
BOOTLDR variable =
B3ECID1-S5#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 18-Jul-11 05:49 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
B3ECID1-S5 uptime is 5 minutes
Uptime for this control processor is 6 minutes
Time since B3ECID1-S5 switched to active is 5 minutes
System returned to ROM by  power cycle at 08:56:43 CET Sun Jul 8 2012 (SP by power on)
System restarted at 09:29:27 CET Sun Jul 8 2012
Last reload reason: bus error at PC 0x425F4270, address 0x0
--More--         third-party authority to import, export, distribute or use encryption.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458720K/65536K bytes of memory.
Processor board ID SMG1213N0B5
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
2 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
--More--         65536K bytes of Flash internal SIMM (Sector size 512K).
PLEASE ADVICE ME
thanks,
Shain Bharati
Leo Laohoo Sun, 07/08/2012 - 15:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you please post the output to the following commands:
1.  dir sup-bootflash:
2.  sh run | b boot-start-marker
shain bharati Mon, 07/09/2012 - 00:48
I can not provide full configuration.
SWITCH#sh run | b boot-start-marker
boot-start-marker
boot-end-marker
Directory of sup-bootdisk:/
    1  -rw-    74638820   Oct 8 2008 21:30:02 +02:00  s72033-ipservicesk9_wan-mz.122-33.SXH3a.bin
    2  -rw-   116776804   Jul 5 2012 14:14:42 +02:00  s72033-advipservicesk9_wan-mz.122-33.SXI7.bin
    3  -rw-        1944   Jul 8 2012 10:03:58 +02:00  vlan0807
    4  -rw-     6390272   Jul 5 2012 14:25:32 +02:00  c6svc-fwm-k9.4-0-3.bin
    5  -rw-     6390272   Jul 5 2012 14:27:12 +02:00  c6svc-fwm-k9.4-0-17.bin
Shain Bharati
Leo Laohoo Mon, 07/09/2012 - 22:03
  • Hall of Fame,
    2017 LAN, Wireless
Can you try this:
conf t
no boo sys flash sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI7.bin
no boo sys flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH3a.bin
end
wr
conf t
end
wr
Related Content
