Using AnyConnect Secure Mobility Client against older ASA images
Answered Question
Jul 9th, 2012
Will AnyConnect Secure Mobility Client 3.x function correctly when the ASA code is less than 8.4?
I thought you cannot use AC 3.x on anything older than ASA 8.4, but does that mean completely unsupported or some things work and others are unsupported? I just need basic vpn connection and authentication to work.
I have to support a mixture of ASAs with different versions, some 8.2(x) and some 8.3(x) and some 8.4(x) and want to know if this is definitely not recommended to even try making a vpn connection and authenticating against older ASA code with the new client.
Thanks.
Correct Answer by rohaverm about 1 year 9 months ago
The VPN portion of the AnyConnect 3.0 client requires ASA 8.0(4). But because of the increased size of the AnyConnect package from 4MB in AnyConnect 2.5 to 21 MB in AnyConnect 3.0, you may need to upgrade the ASA flash and memory card first.
Check the link
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect30/release/notes/anyconnect30rn.html#wp1578520.
Average Rating: 5 (1 ratings)
Correct Answer
rohaverm Mon, 07/09/2012 - 13:04
Check the link
lcaruso Mon, 07/09/2012 - 13:37
Thanks for your reply and the link.
Can I connect with AC 3.x client to ASAs that have 2.x AC image? I thought only the ios version would matter.
Login or Register to take actions
Posted July 9, 2012 at 11:36 AM
Stats:
Replies:2 Avg. Rating:5
Views:425 Votes:0
Shares:0
Categories: AnyConnect
Related Content
Discussions Leaderboard
