problem authenticación with letter ñ
Answered Question
Jul 9th, 2012
i am having problem in 802.1x authenticactión with user who has username pzuñiga(letter ñ). The ASC dont acept the letter "ñ" does someone kown if this has a solutión or  when i can found an official document from cisco.
Best Regard,
Marco.
Correct Answer by Tarik Admani about 5 years 1 month ago
Do you get the same errors when you use the format above or does it pass authentication? There have been a few AD related bugs fixed after patch 3, I would strongly suggest installing this patch to see if the issue is resolved before opening a TAC case.
Tarik Admani
Marcos,
What version of ACS are you using? There is a bug that is fixed in ACS 5.3 -
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.3/release/notes/acs_53_rn.html
CSCta75080
MSCHAP authentication with UTF8 SAM & NETBIOS did not work against  AD in Centrify configuration. This problem is resolved now.
tarik Admani
Overall Rating: 5 (2 ratings)
Correct Answer
Tarik Admani Mon, 07/09/2012 - 14:01
  • Green, 3000 points or more
Marcos,
CSCta75080
tarik Admani
mhuaynate Mon, 07/09/2012 - 14:32
Tarik,
My acs versión is 5.3.0.40.1
Best Regard,
Marco.
Correct Answer
Tarik Admani Mon, 07/09/2012 - 14:34
Tarik Admani
mhuaynate Mon, 07/09/2012 - 14:55
Tarik,
ok i am going to upgrade to ACS versión to 5.3.0.40.5. I wish this resolv the problem.
Best Regard,
Marco.
Tarik Admani Tue, 07/10/2012 - 22:59
Marco,
I wanted to know if this fixed your problem.
Tarik Admani
mhuaynate Wed, 07/11/2012 - 08:14
Tarik,
not yet ... today i am goint to try this in my lab.
Thank.
Marco.
Ivan Bermejo Ch... Thu, 12/27/2012 - 04:39
Hi all,
I am having similar problem with version 5.3.0.40.5, but I have "ñ" character in password field instead of username. When an user with "ñ" character in password tries to authenticate via ACS, communication between ACS an AD fails for couple of minutes, for that user and the followings showing these messages:
24401 Could not establish connection with ACS Active Directory agent
Is there any limitation in this issue?
jrabinow Thu, 12/27/2012 - 04:49
  • Cisco Employee,
I would recommend installing patch 5.3.0.40.6 or later (latest patch is 5.3.0.40.8)
This includes a fix for the following issue
CSCtz83523 AD-Client crashes due to the password with non UTF-8 characters
It does look like you are seeing a similar crash
Related Content
