Inter VLAN-Routing ASA 5505
Answered Question
Jul 9th, 2012
Ive been readin all over the internet (including this site) trying to figure out if the asa can handle intervlan routing. Im not sure what I am missing on my config to get this to work.  Ive read that it can work and Ive read that it cant work.  Can someone lead me in the right direction on how to get this to work on my asa 5505.
Here is my setup
Cable Modem ---> ASA (eth0/0)
                                   (eth0/2) -->unmanaged switch for LAN connectivity
                                   (eth0/3) --> Access point for wireless LAN connectivty
My config is attached
What I would like to do is be able to communicate between vlan3(LAN) and vlan4(Wireless LAN)
Whats strange is I can RDP between the two vlans but I cant ping or anything else.
Any help is appreciated!
Correct Answer by Ramraj Sivagnan... about 5 years 3 weeks ago
Hi Bro
I believe everything is working fine now. Please do paste your latest config here, so that the others could learn from your experience as well.
P/S: If you think this comment is useful, please do rate them nicely :-)
Overall Rating: 5 (4 ratings)
Jouni Forss Mon, 07/09/2012 - 22:33
Personally I would do the following
1.) Change the wifi interface security-level to something like 99
2.) remote the nat command: static (insidewifi,inside) 172.16.2.0 172.16.2.0 netmask 255.255.255.0
3.) Configure icmp inspection so ICMP will pass through without opening both directions for the traffic (echo and reply)
4.) Build access-lists for each interface even though they might be simple
One option with the NAT you have is ofcourse using NAT0/NAT Exempt to tell the ASA that no translation between these networks will be done. Then again I think the ASA doesnt have the "nat-control" configured at the moment so removing both the static translations should still mean your 2 LAN networks should be able to reach each other wihtout using NAT.
- Jouni
The ICMP inspection configuration was
policy-map global_policy
class inspection_default
  inspect icmp
  inspect icmp error
Garland Moore Tue, 07/10/2012 - 21:27
JouniForss, thanks for your response.  I tried your suggested step and I was still unable to talk between the two vlans.  Is my approach to this scenario wrong.  I know ASA arent typically used as Layer devices but from what Ive been reading it can be done.
From my reading it seems like the following alone should allow me to talk across the vlans:
static (inside,insidewifi) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
Sorry for all the questions, Im familiar with routing and switching.  The ASA is kind of a different beast.
Another thing thats weird to me is that, when I do a packet trace is states that the packet is allowed.  Any help is appreciated.
Jouni Forss Tue, 07/10/2012 - 23:22
There should be no problem using the ASA in this kind of setup. Though I'm more used to doing this with the other ASA models. ASA 5510 and onwards where the interface configurations change compared to the ASA5505 (no actual switch ports)
The "same-security-traffic" command basically either permit traffic between interfaces with same security-level or allow traffic to be sent out the same interface it originally came from. In this case only one of them should apply.
Seems strange to me that you can indeed use RDP connections but nothing else works. One would think the problem stems from something else than the firewall settings if some connections go through
Have you been able to send ICMP through the firewall after adding the commands I mentioned? There shouldnt be anything preventhing the Echos/Echo replys other than the devices sending them.
If you want to allow icmp echos on you ASAs interfaces you can use the command
icmp permit any
This command allows you to ping the ASAs interfaces. Notice though that you cant ping a ASA interface behind another ASA interface. You can only ping the interface behind which you are connected.
I typically allow ICMP on all interfaces that arent connected to public network/Internet.
Naturally, if you have some TCP connection that you can use to test traffic between these Vlans, try it out and at the same time monitor the traffic through ASDM and see what happens to the connection. Does the connection get built on the ASA but is it beeing torn down by SYN Timeout or whats happening?
- Jouni
Garland Moore Wed, 07/11/2012 - 22:00
So Ive made the changes you suggested but Im still unable to get the functionality I am looking for. My config is below after the changes.
ASA Version 8.2(2)
hostname frw01
enable password .MlTybcgwEXNF1HM encrypted
passwd .MlTybcgwEXNF1HM encrypted
names
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
no forward interface Vlan4
nameif guest
security-level 50
ip address 172.16.10.1 255.255.255.0
interface Vlan4
nameif inside
security-level 99
ip address 172.16.1.1 255.255.255.0
interface Vlan5
nameif insidewifi
security-level 100
ip address 172.16.2.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
switchport access vlan 4
interface Ethernet0/3
switchport access vlan 5
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
object-group icmp-type DefaultICMP
description Default ICMP Types permitted
icmp-object echo-reply
icmp-object unreachable
icmp-object time-exceeded
access-list icmp_outside extended permit icmp any any object-group DefaultICMP
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu guest 1500
mtu inside 1500
mtu insidewifi 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any insidewifi
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (guest) 1 172.16.10.0 255.255.255.0
nat (inside) 1 172.16.1.0 255.255.255.0
nat (insidewifi) 1 172.16.2.0 255.255.255.0
access-group icmp_outside in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 172.16.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 172.16.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
management-access inside
dhcpd dns 172.16.1.102
dhcprelay server 172.16.1.102 inside
dhcprelay enable guest
dhcprelay enable insidewifi
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username ******** password PNUmTwjDhevRqhkT encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:3fcbac02b3e4b4e6919cf34a9137b4fb
Below is the error message that I receive when trying to connect to an access point on a different subnet.
2Jul 11 201223:52:18106001172.16.1.20050262172.16.2.180Inbound TCP connection denied from 172.16.1.200/50262 to 172.16.2.1/80 flags SYN  on interface inside
Maybe I have some over kill here and should start from scratch and change my approach.  It seems that my like of experience with the asa is part of the issue.
Suggestions or thoughts?
Jouni Forss Wed, 07/11/2012 - 23:26
Seems to me that the log message implies that the host (inside) 172.16.1.200 is connecting to the ASA interface (insidewifi). (TCP SYN to interface IP)
This will naturally be blocked. In the same way an ICMP from behind the "inside" interface to the "insidewifi" would be blocked.
Why are you connecting to the ASA interface IP?
- Jouni
Jouni Forss Wed, 07/11/2012 - 23:34
Also,
Have you considered configuring a trunk between the ASA 5505 and the local switch? Since at the moment you just have access ports for all the Vlan interfaces on the ASA.
I presume you have gotten the ASA with something else than the Base license since you have over 3 interfaces on it. To my understanding.
Unfortunately i so rarely deal with the ASA5505 that I have forgotten some of the differences it has to the later models.
- Jouni
Garland Moore Thu, 07/12/2012 - 06:27
The log above was generated when trying to ping a host on a different vlan.  I wasnt attempting to connect to the ASA interface IP/  The switch connected to the ASA is an unmanaged switch so I didnt think a trunk was necessary since everything connected to that switch will be on the same vlan.
The ASA does have a Security Plus license.
Jouni Forss Mon, 07/16/2012 - 02:12
I guess by ping you are refering to some application testing TCP traffic (sameway the newer ASA software versions have TCP ping)? An actual ICMP echo wouldnt generate that message.
I assume the unmanaged switch is only connected to the port Ethernet0/2 on the ASA? (only for interface "inside" users)
- Jouni
Ramraj Sivagnan... Mon, 07/16/2012 - 02:35
  • Silver, 250 points or more
Hi Bro
Based on your requirement as stated in this subject, you want to PING between Vlan3 and Vlan4. This is not hard. Just follow the comments I've give you below, and you will do just fine :-)
interface Vlan3
no forward interface Vlan4  <-- remove this line!!!!!!!!!!!!!!!
nameif guest
security-level 50
interface Vlan4
nameif inside
security-level 100
icmp-object echo <-- add this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
no access-list icmp_outside extended permit icmp any any object-group DefaultICMP
no access-group icmp_outside in interface outside
access-list guest permit icmp any any object-group DefaultICMP
access-list guest deny ip any any log
access-group guest in interface guest
access-list inside permit icmp any any object-group DefaultICMP
access-list inside deny ip any any log
access-group inside in interface inside
static (inside,guest) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
By the way, could you also paste the output of this command "show threat-detection shun" here, as well.
If this still doesn't work, paste your latest show run output here. This should be easy and fast :-) Good luck bro
Garland Moore Mon, 07/16/2012 - 19:14
Ramraj, thanks for your response!  Here what Im attempting to do...
I would like to have 4 VLANs
Vlan2 -- Outside
Vlan3 -- Guest Wifi
Vlan4 -- Inside LAN
Vlan5 -- Inside LAN Wifi
I would like to allow any communication between Vlan 4 and Vlan 5.
I would then like Vlan4 and Vlan5 to access Vlan 3 but not vice versa (not critical for this functionality to work)
I would like all the Vlans to have access to the internet.
I know the ASA is not a router but can act as one (kinda).  The "show threat-detection shun" command didnt return any results.  I appreciate any assistance with helping me get this up and running.
Here is my latest config
: Saved
ASA Version 8.2(2)
hostname frw01
names
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif guest
security-level 50
interface Vlan4
nameif inside
security-level 99
interface Vlan5
nameif insidewifi
security-level 100
shutdown
shutdown
shutdown
shutdown
ftp mode passive
pager lines 24
logging enable
mtu outside 1500
mtu guest 1500
mtu inside 1500
mtu insidewifi 1500
no failover
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
username ***** password PNUmTwjDhevRqhkT encrypted privilege 15
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
  inspect icmp error
call-home
profile CiscoTAC-1
  no active
Cryptochecksum:d41d8cd98f00b204e9800998ecf8427e
: end
Ramraj Sivagnan... Mon, 07/16/2012 - 22:56
Hi Bro
Please delete / write erase your present FW configuration, and paste the configuration shown below. This will work. I've done it too many times, to know this will work :-)
Please ensure the hub or switch connected to each of the FW interface is different, for security and network performance purposes e.g. Ethernet0/0 - 0/3.
As for the rules portion, let's keep it loose for now. Once all is good, we can then tighten them yaa :-)
Let me know how it goes...
hostname FW01
enable password cisco
passwd cisco
interface Vlan2
description ### Link to Internet ###
nameif outside
security-level 0
interface Vlan3
description ### Link to GUEST WIFI  ###
nameif guest
security-level 50
interface Vlan4
description ### Link to INSIDE LAN ###
nameif inside
security-level 100
interface Vlan5
description ### Link to INSIDE WIFI ###
nameif insidewifi
security-level 50
shutdown
shutdown
shutdown
shutdown
no nat-control
access-list inside extended permit ip any any
access-list outside extended permit ip any any
access-list guest extended permit ip any any
access-list insidewifi extended permit ip any any
access-group outside in interface outside
access-group insidewifi in interface insidewifi
http server enable
username cisco password cisco privilege 15
dhcpd ping_timeout 750
dhcprelay setroute guest
dhcprelay setroute insidewifi
Garland Moore Tue, 07/17/2012 - 21:01
Ok, so I took your advice and pasted your config.  Now the only host on the inside vlan can get to the internet.  The other vlans get ip addresses but that it.  Ive gotta be missing something simple here.
Here is my config:
hostname FW01
names
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif guest
security-level 50
interface Vlan4
nameif inside
security-level 100
interface Vlan5
nameif insidewifi
security-level 50
shutdown
shutdown
shutdown
shutdown
ftp mode passive
pager lines 24
mtu outside 1500
mtu guest 1500
mtu inside 1500
mtu insidewifi 1500
no failover
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
no threat-detection statistics tcp-intercept
webvpn
username ****** password PNUmTwjDhevRqhkT encrypted privilege 15
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
profile CiscoTAC-1
  no active
Cryptochecksum:28bf26da86f44244c8f0e4768f75ee70
: end
Ramraj Sivagnan... Tue, 07/17/2012 - 21:14
Hi Bro
You Cisco ASA config is good but I'm suprised only INSIDE can access the Internet. Can you confirm the following;
a) LAN users in insidewifi and guest can PING to its' gateway i.e. the Cisco ASA itself?
b) LAN users in insidewifi and guest can PING to any Public IP Address e.g. 8.8.8.8?
c) LAN users in insidewifi and guest can PING to any Public FQDN e.g. www.yahoo.com?
d) Is the DNS Server settings in insidewifi and guest correct? as in it's the same as inside users. Is the nslookup output the same?
e) Can you paste the show xlate, and show access-list output here?
Garland Moore Tue, 07/17/2012 - 22:22
I added the static nat commands below and my Vlans can now talk to the internet.
Are these necessary?
Ramraj Sivagnan... Tue, 07/17/2012 - 22:37
This Is weird :-) I've never seen anything like this before. Are you sure you have keyed in the command "no nat-ncontrol"?
Garland Moore Wed, 07/18/2012 - 20:02
Bro,
From my understanding the ASA 5505 has nat control disabled by default.  I issued the command anyway, and removed the static nat commands but I was still unable to access the internet. The only way internet access will work is if I have the static NAT commands.
Here is the config
ASA Version 8.2(2)
hostname FW01
names
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif guest
security-level 50
interface Vlan4
nameif inside
security-level 100
interface Vlan5
nameif insidewifi
security-level 50
shutdown
shutdown
shutdown
shutdown
ftp mode passive
pager lines 24
mtu outside 1500
mtu guest 1500
mtu inside 1500
mtu insidewifi 1500
no failover
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
profile CiscoTAC-1
  no active
Cryptochecksum:6599fa7a5e196a7dfaa544f75cd64ae7
: end
Correct Answer
Ramraj Sivagnan... Sun, 07/22/2012 - 13:17
Hi Bro
Garland Moore Sun, 07/22/2012 - 13:40
Here is the working config.  Many thanks to Ramraj for his assistance!!!!!
ASA Version 8.2(2)
hostname FW01
names
dns-guard
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif guest
security-level 50
interface Vlan4
nameif inside
security-level 100
interface Vlan5
nameif insidewifi
security-level 50
shutdown
shutdown
shutdown
shutdown
banner exec
banner exec ******* ENGLISH *** ATTENTION *** ENGLISH *** ATTENTION *** ENGLISH **********
banner exec *
banner exec *      This system is for the use of authorized users only.
banner exec *      Individuals using this system are subject to having all of their
banner exec *      activities on this system monitored and recorded by system
banner exec *      personnel.
banner exec *
banner exec *      Anyone using this system expressly consents to such monitoring
banner exec *      and is advised that if such monitoring reveals possible
banner exec *      evidence of criminal activity, system personnel may provide the
banner exec *      evidence of such monitoring to law enforcement officials.
banner exec *
banner exec
banner exec
banner exec Name:.......FW01
banner exec Address:....**********
banner exec Location:...CST -5
ftp mode passive
clock timezone CST -5
access-list guest extended permit udp any host 172.16.1.102 eq domain
access-list guest extended permit udp any host 172.16.1.103 eq domain
access-list guest extended permit udp any any range bootps tftp
access-list guest extended deny ip any 172.16.1.0 255.255.255.0 log
access-list guest extended deny ip any 172.16.2.0 255.255.255.0 log
no pager
logging enable
logging list TEST level alerts
logging buffered debugging
logging mail TEST
logging from-address *firewall domain name*
logging recipient-address *enter email address here* level errors
mtu outside 1500
mtu guest 1500
mtu inside 1500
mtu insidewifi 1500
ip audit name FW01-INFO info action alarm
ip audit name FW01-ATTACK attack action alarm reset
ip audit interface outside FW01-INFO
ip audit interface outside FW01-ATTACK
ip audit signature 2000 disable
ip audit signature 2001 disable
ip audit signature 2004 disable
ip audit signature 2005 disable
no failover
icmp permit any echo-reply outside
icmp permit any guest
arp timeout 14400
http server enable
fragment chain 1 outside
sysopt noproxyarp outside
service resetoutside
telnet timeout 5
ssh timeout 60
console timeout 0
threat-detection scanning-threat shun except ip-address 172.16.0.0 255.255.0.0
ntp server 211.233.40.78
ntp server 61.153.197.226
ntp server 202.150.213.154 prefer
webvpn
username *username here* password PNUmTwjDhevRqhkT encrypted privilege 15
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
smtp-server 173.194.79.109
call-home
profile CiscoTAC-1
  no active
Cryptochecksum:69ead0d0578ac025238d9a7a25f48f13
Julio Carvajal Sun, 07/22/2012 - 15:03
  • Purple, 4500 points or more
Hello Garland,
Here is what I want you to try to make this work:
Add the following commands
1- fixup protocol ICMP
2-static (guest,inside) 172.16.10.0  172.16.10.0 netmask 255.255.255.0
Then try to ping from inside to guest, and backwards if that does not work do the following:
packet-tracer input inside icmp 172.16.1.20 8 0 172.16.10.10
packet-tracer input guest icmp 172.16.10.10. 8 0 172.16.1.20
The CSC is a free support community, take your time to rate all of the engineers support
mach825 Tue, 10/22/2013 - 08:03
Hello all,
I am struggling to get intervlan routing to function properly on my ASA 5505.  I have a security plus license.  The VLANs I am dealing with are inside, Developer, and outside.
description outside
description inside
switchport trunk allowed vlan 1,24
description Wireless Access Point
switchport trunk native vlan 1
switchport mode trunk
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address nnn.nn.nn.nnn 255.255.255.0
interface Vlan24
nameif Developer
security-level 100
ip address 192.168.24.1 255.255.255.0
access-list acl-inside_dev extended permit ip any any
access-list acl-Developer extended permit ip any any
access-group acl-inside_dev in interface inside
access-group acl-Developer in interface Developer
Shannon
Related Content
