B-ACD not working?
Jul 5th, 2012
Hi all,
I am trying to configure B-ACD on my CME (using instructions from the Cisco site) and can't seem to get it to work. Can anyone suggest a configuration example that would assist me? What is currently happening is, a call is placed to the FXO from a cell phone. ACD answers, you hear a busy tone for a few seconds and then ACD disconnects the caller, no dropthrough at all. The setup I need is as follows -
A call is detected on POTS/PSTN line (FXO) at voice-port 0/0/0. It is immediately routed via drop-through to a sequential hunt group (extensions 101, 102, and then if not answered finally to voicemail extension 701).When a call comes in from this line it should display as "From Landline Call" (extension 601) - aa extension number. This is to avoid incoming calls that come up as"Unknown Number". This should be able to be acomplished using the directory entry command.
Ideas?
Nic.
NicP270591 Fri, 07/06/2012 - 18:20
I have configured it to a sequential hunt instead, but the same issue exists. Config below:
service Queue flash:B-ACD/app-b-acd-3.0.0.2.tcl
  param queue-len 50
  param aa-hunt3 623
  param aa-hunt1 621
  param aa-hunt2 622
  param queue-manager-debugs 1
  param number-of-hunt-grps 3
service 601 flash:/B-ACD/app-b-acd-aa-3.0.0.2.tcl
  paramspace english index 0
  param call-retry-timer 1
  paramspace english language en
  param drop-through-option 2
  param second-greeting-time 30
  paramspace english location flash:/B-ACD/
  param max-time-vm-retry 1
  param max-time-call-retry 28
  param voice-mail 701
  param aa-pilot 601
  param number-of-hunt-grps 1
  param handoff-string 601
voice-port 0/0/0
supervisory disconnect dualtone mid-call
compand-type a-law
cptone AU
timeouts call-disconnect 3
timeouts wait-release 3
impedance complex1
caller-id enable
dial-peer voice 601 pots
description ****Landline Queue****
service 601
direct-inward-dial
port 0/0/0
directory entry 2 601 name Landline Call
ephone-hunt 2 sequential
pilot 621
list 101, 102
timeout 30, 30
no-reg pilot
statistics collect
I call into the FXO port via a cellphone. I can see the green LED on the port light up with the ringtone. The call however, is routed nowhere. I dial 621 from an IP Phone and the sequential hunt rings and works perfectly. Wondering if it is maybe an issue with the local call progress tones (Australia) not being detected by CME correctly, even though I have configured CP Tone on the port?
When configuring parameters I get a warning on every parameter command, however, I have read that this warning can be ignored and is not applicable to my situation. An example of the warning after entering the queue-len command is below:
"Warning: parameter queue-len has not been registered under queue namespace"
I am completely out of ideas, done as much research as possible with no luck, and getting rather frustrated Please advise if you can see anything that is wrong!
Nic.
