Warning message
Discovering the swicth containing an ace module
Answered Question
Jul 10th, 2012
Hi all,
I have a doubt.
I am working in a ACE load balancer and now I want to discovery which swicth is contining that ACE module.
How cai I get this information???
Thank you!!!
Correct Answer by Jorge Bejarano about 5 years 1 month ago
Hello Fabio,
Your question is very interesting.
Currently the ACE module does not have command like that.
What you can do is to run these commands below to see the slot number and try to map using the mac addresses.
#show arp
#show interfaces
#show hardware.
Probably, you may need to ask for a enhancement request.
Hope this helps!!!
Jorge
Overall Rating: 4.3 (3 ratings)
Jorge Bejarano Tue, 07/10/2012 - 16:17
  • Silver, 250 points or more
Hello Fabio,
I am sorry, I am not sure about your question.
You said you want to know how you can determine if a switch contains an ACE module, correct?
Mmm, well, you can do # show module
Jorge
fabio.marino Wed, 07/11/2012 - 05:23
My question is: from the ACE how can udesratnd the swicth contoning this module?
You answered to the reverse question.
Thank you the same for your time of course :-).
Bye.
rathinilesh Wed, 07/11/2012 - 04:06
Hi Fabio,
As Jorge mentioned you can issue a "show module" command on the devices in your core network. This will provide you with a list of all the modules installed on the respective devices. As ACEs can be installed on the Cisco Catalyst 6500 Series Switches and Cisco 7600 Series Routers, thus these are the only devices you need to do a "show module" on thus saving you some time.
http://www.cisco.com/en/US/products/ps6906/index.html
Nilesh
Correct Answer
Jorge Bejarano Wed, 07/11/2012 - 09:20
Hello Fabio,
#show arp
#show interfaces
#show hardware.
Hope this helps!!!
Jorge
Jorge Bejarano Wed, 07/11/2012 - 19:45
Hello Fabio,
Then, in summary:
From the switch to get the details of th ACE you can do: #show module
Switch--->#show module --->ACE
From the ACE to get the details of the Switch, there´s NO command to get those details, currently.
ACE----> X Switch
Please mark it, if you consider it useful.
Hope this helps.
Jorge
fabio.marino Thu, 07/26/2012 - 03:35
Hi Jorge,
So I have to go thorugh an analysis of the network topology in order to solve my doubt.
Thanks for your time.
