show ip router summary this command explain !
Answered Question
Jul 10th, 2012
Hello all ~
I am study the ccnp but I don't understand this command "show ip router summary"
who can explain ?
how can I compare this command and config ?
R2#sh ip route summary
IP routing table name is Default-IP-Routing-Table(0)
Route Source    Networks    Subnets     Overhead    Memory (bytes)
connected       0           4           256         608
static          0           0           0           0
internal        2                                   2344
Total           2           4           256         2952
R2#
interface Loopback1
ip address 192.168.200.1 255.255.255.252
interface Loopback5
ip address 192.168.200.5 255.255.255.252
interface Loopback9
ip address 192.168.200.9 255.255.255.252
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 172.16.1.1 255.255.255.0
Correct Answer by Sandeep Choudhary about 5 years 2 weeks ago
Hi Cash,
show ip route summary
static                         0                      0                  0                  0
internal                     2                                                            2344
Total                          2                      4               256              2952
Table 60     show ip route summary Field Descriptions
Field
Description
Route Source
Routing protocol name, or the connected, static, or internal keyword. "Internal" indicates those routes that are in the routing table that are not owned by any routing protocol.
Networks
Number of prefixes that are present in the routing table for each route source.
Subnets
Number of subnets that are present in the routing table for each route source, including host routes.
Overhead
Any additional memory involved in allocating the routes for the particular route source other than the memory specified in the Memory field.
Memory
Number of bytes allocated to maintain all the routes for the particular route source.
Please rate if it helps.
Overall Rating: 4.5 (3 ratings)
Correct Answer
Sandeep Choudhary Tue, 07/10/2012 - 13:40
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Cash,
static                         0                      0                  0                  0
internal                     2                                                            2344
Total                          2                      4               256              2952
Field
Description
Route Source
Networks
Subnets
Overhead
Memory
Ganesh Hariharan Wed, 07/11/2012 - 06:26
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello ,
As stated by the above post ip route summary gives you the current state of the routing table, like where excatly the routes originated and how many prefix are been used by routig protocol with number of bytes used by routes.
This command is mainly used to check the state of the routing table.
Hope to help !!
Ganesh
