CVP Menu Microapp Disable Built-in CVP prompts
Jul 10th, 2012
I am trying to configure a menu microapp to repeat the prompt in case of wrong or no entry, the configuration is as follows:
1-2,,2,2,2
Interruptible and Overridable boxes are not checked.
The configuration works, and the prompt is repeated twice in case of wrong or no entry, however, there is a CVP prompt is played ( in case of wrong entry: You made a wrong entry), how can I disable this built-in prompts? I need the prompt to be repeated without any other built-in prompts, is it doable?
Many Thanks,
Yousef Bustami
