Warning message
configuring netflow for layer 2 switched traffic on my cat6509
Jul 11th, 2012
Hi all
I want to configure layer 2 switched netflow on my cat 6509 running vss,
I have configured the 2 commands below
ip flow ingress layer2-switched vlan 1,2,3
ip flow export layer2-switched vlan 1,2,3
However, if I look in the config the export bit isnt there after?
It is running a PFC
VS-F6K-PFC3C
Should layer 2 switched netflow work in this chassis ?
it says on the Cisco site that it works on the below
"The command is supported on Supervisor Engine 720 in PFC3B and PFC3BXL mode only and on Supervisor Engine 2 with a PFC2"
so is it not possible for me ?
cheers
Overall Rating: 3 (1 ratings)
Giuseppe Larosa Wed, 07/11/2012 - 02:06
  • Hall of Fame,
    Founding Member
Hello Carl,
it should be supported you have a PFC3C > PFC3B
see
Except in PFC3A mode, NetFlow supports bridged IP traffic. PFC3A mode does not support NetFlow bridged IP traffic.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/netflow.html#wp1106378
Edit:
only the first command is reported in cfg guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/netflow.html#wp1157805
the NDE export part should be configured as usual as you do for the routed traffic.
Hope to help
Giuseppe
Related Content
