Wired network/Tunnel through WAN
Jul 11th, 2012
Is there a way where we can get wired network work in similar way with Lightweight AP work, I mean the Lightweight AP works as a tunnel when users connect through it in a WAN network.
Ali
Sebastian Helmer Wed, 07/11/2012 - 07:51
  • Silver, 250 points or more
U can use The Cisco 600 which allows 15 wireless and 4 wired clients on one port, so u need a mini switch or hub.
Sebastian
alialjamri2008 Thu, 07/12/2012 - 00:49
I think my question was miss understood, what I need is to connect our 2960 switches at the remote locations through WAN to our core switch 3750 on our data center by using tunneling or any other way, I am thinking to get something similar to lightweight AP with the Wireless controller operation.
Ali
blackbrayn Thu, 07/12/2012 - 01:06
i think we need more info about wan , are you using services form a isp or it's your network between sites?
