Warning message
test voice port 0/2/0 si-reg-read 29 1 on fxo port
Jul 11th, 2012
  • Cisco Designated VIP,
    2017 IP Telephony
Guys,
Is there any documentation that explains what the output of this commad mean. I am troubleshooting a fxo port and from this output it l ooks like I have a cable problem. I am only saying this because I had a similar issue and the outpur was Register 29 = 0XCE and it turned out it was a cacling issue.
I will like to know what to make of the results.
What does Register 29 = 0xCC or 0xCD mean?
Jul 11 15:40:44.356 GMT:
GDN1UK-0027S-ERT01#test voice port 0/2/0 si-reg-read 29 1
GDN1UK-0027S-ERT01#
Jul 11 15:41:25.716 GMT:
Values read from SiLabs Codec connected to DSP 0, channel 0:
Register 29 = 0xCC
GDN1UK-0027S-ERT01#
Jul 11 15:41:29.796 GMT:
Register 29 = 0xCD
GDN1UK-0027S-ERT01#
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
paolo bevilacqua Wed, 07/11/2012 - 08:46
  • Hall of Fame,
    Founding Member
Aok, I think you know already that test commands and internal data and registers are undocumented
Ayodeji Okanlawon Wed, 07/11/2012 - 08:48
    2017 IP Telephony
Thanks Paolo, Didnt realise that. What do you think is the case with the result here..Any idea? Cable issue?
paolo bevilacqua Wed, 07/11/2012 - 08:56
  • Hall of Fame,
    Founding Member
Isn't that the register supposed to reflect presence of loop current ?
I've always tought that the same can be done trying to place an outboud calls, it will fail with a 'no dialtone' in debug vpm signal.
Ayodeji Okanlawon Wed, 07/11/2012 - 09:07
    2017 IP Telephony
I always expect that value 0x33 reflect the presence of a loop current or that a voltage is present on the line. But I have just tested the line now and it works! Thats odd and interesting.
