Help with autonomous wireless access point, dot1x and guest VLAN
Jul 12th, 2012
Please can someone help with this as I'm tearing my hair out!
Hardware: Cisco 3750 switch and Cisco autonomous access point (AIR-AP1142N-E-K9).
Requirement: A single broadcast SSID; use dot1x to assign vlan 98 to authenticated clients (computer certificate); assign vlan 3 (guest) if the authentication fails.
I can achieve assigning a guest vlan on authentication failure when using a wired connection by using the following command on the interface:
authentication event fail action authorize vlan 3
I'm after a way to achieve the above using the wireless access point.
The main point is that internal users cannot access vlan 3 as they have a valid certificate and that guests do not have to authenticate.
Many thanks in advance
Amjad Abdullah Thu, 07/12/2012 - 06:03
  • Red, 2250 points or more
Well, if you have ACS 5.x as radius you can configure policies so that assign vlan x for succeeded clients and vlan y for failed clients. I dont think what you eant is available from AP side configuration.
stefan.angerer Mon, 07/16/2012 - 12:21
  • Bronze, 100 points or more
unfortunately you cannot do this.
Since the (necessary) WPA(2) key handshake relies on a successful authentication, there is no such thing like a auth-failed vlan when doing wireless. Usually people work around that using a dedicated guest SSID.
regards
Stefan
Related Content
Trending Topics - Security & Network
