Warning message
Multicast between subnets
Answered Question
Jul 12th, 2012
We are trying to get multicast to work between two subnets but cannot seem to get it to work  We have the following configuration
multicast video - teradek cube - 10.223.21.101
  multicast - 239.1.254.1
  rtsp://10.223.21.101/stream1
client-a - 10.223.21.100
switch-a - 2960
router-a - 3725 - 10.223.21.1 (fa0/0.1)
fa0/1 - 10.0.10.9
fa0/1 - 10.0.10.101
router-b - 3725 - 10.223.99.1 (fa0/0.1)
switch-b - 2960
clent-b - 10.223.99.200
Client A and the multicast video server are connected to switch-a
Client B is connected to switch-b
Client A can access the multicast video
Client B cannot access the multicast video
Here is the configs
router-a
ip multicast-routing
int fa0/0
  no ip addr
int fa0/0.1
  desc local network
  encap dot1q 1 native
  ip addr 10.223.21.1 255.255.255.0
  ip pim sparse-mode
int fa0/1
  ip addr 10.0.10.9 255.255.255.0
  ip pim sparse-mode
ip pim autorp listner
ip pim send-rp-announce fa0/1 scope 8
ip pim send-rp-discovery fa0/1 scope 8
router-b
int fa0/0
  no ip addr
int fa0/0.1
  desc local network
  ip addr 10.223.99.1 255.255.255.0
  ip pim sparse-mode
int fa0/1
  ip addr 10.0.10.101 255.255.255.0
  ip pim sparse-mode
Correct Answer by Edison Ortiz about 5 years 1 month ago
There aren't any joins on the 'B' side. Verify the client's application TTL setting is greater than 1.
Overall Rating: 5 (1 ratings)
John Blakley Thu, 07/12/2012 - 14:37
  • Purple, 4500 points or more
Can you post a quick diagram of how this is connected?
Also, can you post:
sh ip pim interfa
sh ip pim rp
sh ip mroute 239.1.254.1
sh ip pim rp mapping
sh ip pim autorp
HTH,
John
dtom Fri, 07/13/2012 - 08:17
Here is how things are connected:
router - 10.223.21.1
er-SPARE2#sh ip pim inter
Address          Interface                Ver/   Nbr    Query  DR     DR
                                          Mode   Count  Intvl  Prior
10.223.21.1      FastEthernet0/0.1        v2/S   0      30     1      10.223.21.1
10.0.10.9        FastEthernet0/1          v2/S   1      30     1      10.0.10.101
er-SPARE2#sh ip pim rp
Group: 239.1.254.1, RP: 10.0.10.9, v2, v1, next RP-reachable in 00:01:09
Group: 239.255.255.250, RP: 10.0.10.9, v2, v1, next RP-reachable in 00:00:45
Group: 228.67.43.91, RP: 10.0.10.9, v2, v1, next RP-reachable in 00:01:09
er-SPARE2#sh ip mroute 239.1.254.1
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.1.254.1), 00:00:29/stopped, RP 10.0.10.9, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    FastEthernet0/0.1, Forward/Sparse, 00:00:29/00:02:38
(10.223.21.103, 239.1.254.1), 00:00:27/00:02:58, flags: PT
  Incoming interface: FastEthernet0/0.1, RPF nbr 0.0.0.0
  Outgoing interface list: Null
er-SPARE2#sh ip pim rp mapping
PIM Group-to-RP Mappings
This system is an RP (Auto-RP)
This system is an RP-mapping agent (FastEthernet0/1)
Group(s) 224.0.0.0/4
  RP 10.0.10.9 (?), v2v1
    Info source: 10.0.10.9 (?), elected via Auto-RP
         Uptime: 19:09:00, expires: 00:02:59
er-SPARE2#sh ip pim autorp
AutoRP Information:
  AutoRP is enabled.
  AutoRP groups over sparse mode interface is enabled
PIM AutoRP Statistics: Sent/Received
  RP Announce: 5302/4055, RP Discovery: 5345/0
router - 10.223.99.1
er-CARVER#sh ip pim inter
10.223.99.1      FastEthernet0/0.1        v2/S   0      30     1      10.223.99.1
10.0.10.101      FastEthernet0/1          v2/S   1      30     1      10.0.10.101
er-CARVER#sh ip pim rp
er-CARVER#sh ip mroute 239.1.254.1
Group 239.1.254.1 not found
er-CARVER#sh ip pim rp mapping
         Uptime: 19:09:03, expires: 00:02:47
er-CARVER#sh ip pim autorp
AutoRP Information:
  AutoRP is enabled.
  RP Announce: 0/0, RP Discovery: 0/4081
er-CARVER#
Correct Answer
Edison Ortiz Fri, 07/13/2012 - 08:51
  • Hall of Fame,
    Founding Member
dtom Fri, 07/13/2012 - 14:57
That was it, the TTL setting.  Thanks.
Related Content
