nkarthikeyan Fri, 07/13/2012 - 07:46
  • Gold, 750 points or more
Yes... we can make...
IPSec VPN
The Cisco 3800 Series Module (AIM-VPN/SSL-3) can provide hardware-based  IPSec encryption services of 160 and 185 Mbps in the Cisco 3825 and 190  and 210 Mbps in the Cisco 3845 (IPSec IMIX and 1400-byte packets). 1
But make sure that your router is not C3825-NOVPN model.... NOvpn models have limited security features.....
for use make use of the security bundle......
Javier Portuguez Fri, 07/13/2012 - 13:49
  • Red, 2250 points or more
Make sure your IOS includes cryptographic support (k9) and that the previous post is true.
Thanks.
Vinh Phan Le Tien Fri, 07/13/2012 - 22:19
Hi all.
Thanks for your respond.
But I can't find any IOS for Router 3825C support VPN.
When I use 3825 IOS, router can't run.
I read that they can only support SSL VPN with IOS 3825c-spservice. . .
Javier Portuguez Sat, 07/14/2012 - 13:43
Hi Vinh,
Please attach the "show version" output of your Router.
Thanks.
Vinh Phan Le Tien Sun, 07/15/2012 - 18:25
Router#show version
Cisco IOS Software, 3800C Software (C3825C-SPSERVICESK9-M), Version 15.0(1)M8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 16-Feb-12 03:18 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T15, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System image file is "flash:c3825c-spservicesk9-mz.150-1.M8.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco CISCO3825C/K9 (revision 1.2) with 488447K/35840K bytes of memory.
Processor board ID FGL161411MJ
6 FastEthernet interfaces
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
447K bytes of NVRAM.
126976K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO3825C/K9         FGL161411MJ
Hi Javier.
This is details of "show version" command.
Pls help me check.
Thanks and Best Regards,
Vinh Phan
Javier Portuguez Mon, 07/16/2012 - 07:56
Dear Vinh,
Please check the following IOS image:
c3825-advsecurityk9-mz.151-4.M4.bin
http://tools.cisco.com/squish/23783
Please check the IOS requirements, I would do it for you but I am at work right now and working on multiple issues
Keep me posted.
Vinh Phan Le Tien Mon, 07/16/2012 - 18:32
Dear Javier.
Thanks for your support.
I checked with your IOS:
But it didn't work.
After that when I used IOS
c3825c-advipservicesk9-mz.150-1.M8.bin
It's now ok.
Notice that you can't use IOS c3825-.... for router 3825C/K9.
You must use IOS c3825c-...
Thanks all!
Best Regards,
Vinh Phan
Related Content
