Warning message
Dial Plan problem
Answered Question
Jul 13th, 2012
I have a problem implementing my dial plan on CUCM 8.6.
I have a translation pattern 049.1XXX (Predot) for internal calls . When i try to call an external number 0491509352 i receive a message from CUCM saying thet the call cannot be completed and the call is not routed to the gateway. I know it's normal because there is no extension 1509 on CUCM.
How can i resolve this problem without adding any digit?
Thank you in advance
Correct Answer by ronpatel about 5 years 1 month ago
HI
Please de select Urgent Priority in  Translation Pattern Configuration. This will resolve your issue.
Ronak Patel
Rate helpful posts.
Overall Rating: 5 (1 ratings)
ronpatel Fri, 07/13/2012 - 02:49
  • Blue, 1500 points or more
Do you have route pattern for this number 0491509352?
Ronak Patel
nikshah Fri, 07/13/2012 - 03:20
  • Cisco Employee,
Hi Youssef,
Still a little unclear as to what are your requirements, can you trace the call flow something like this
ip phone-->> TP-->> CUCM-->> Gw etc... and let us know what you are looking to achieve.
Niket
Youssef Aoufi Fri, 07/13/2012 - 03:28
i have an internal extensions 1000 , 1001 ... 1010 in Germany Partition.
Ip phones on other partitions (usa, france etc...) shoul call 04910XX to reach this phones. that's why i created a translation pattern 049.1XXX to reach them from other regions.
At the same time , i want to call a PSTN number : 0491509352 that cannot be routed because it matches the translation pattern and not the route pattern 04XXXXXXXX .
I don't want to add an additional digit .
Correct Answer
ronpatel Fri, 07/13/2012 - 03:34
HI
Ronak Patel
Rate helpful posts.
Related Content
