07-13-2012 03:52 AM - edited 03-17-2019 11:27 PM
I got the new Jabber client for the iPad2, and tried to let it register to our VCS e Starterpack.
But it failt to do so.
Do I need to up date the VCS Starterpack software to X7.2 ? Or is there no Starter Pack support.
Solved! Go to Solution.
09-04-2012 12:19 AM
Update, plan to support Jabber for iPad on VCS Starter Pack from next maintenance release, X7.2.1.
Sample snapshot of user account configuration (just sample and this may change before final release).
11-23-2012 06:18 AM
Did you use the non-AES tar.gz file (s42701) on an AES system (s42700) by mistake - they use different release keys - I've made that mistake in the past.
07-13-2012 05:44 AM
Unfortunately Jabber for iPad client is not yet supported by VCS Starter Pack as provisioning client.
Cisco is looking into this now.
07-14-2012 04:58 AM
We have a number of folks using the starterpack and wondering the same thing. Any roadmap or eta?
07-14-2012 05:36 AM
This point no commitment which software version will support, but yes, Cisco plan to add Jabber for Video iPad to the VCS Starter Pack as provisioning client.
07-14-2012 06:36 AM
Is there à work around posible To get Jabber working on The iPad in combinaton with The VCS starterpack.
By up loading a config file or so.
09-04-2012 12:19 AM
09-05-2012 04:54 PM
Looks Great!
11-05-2012 06:16 AM
Hi BW
X7.2.1 is now available from www.cisco.com
Guy
11-23-2012 06:15 AM
I triest to upgrade The VCS but I got The error that The release key is not correct. What is strange becouse The unit is allready running On X7.2.
Any Idee?
11-23-2012 06:18 AM
11-23-2012 06:58 AM
Yes I did ........
