MSE not responding
Jul 13th, 2012
  Hi all
I am currently having trouble adding an MSE to NCS.
I get a message from the NCS to say that the MSE server will not respond when I try to add it.
I have verified that the NCS has IP connectivity to the MSE by switching my laptop for the MSE and taking its IP address.
I have also verifed that the service is running with the command /etc/init.d/msed status
Starting MSE Platform, Waiting to check the status.
MSE Platform is up, getting the status
Server Config
Product name: Cisco Mobility Service Engine
Version: 7.0.201.204
Hw Version: V01
Hw Product Identifier: AIR-MSE-3310-K9
Hw Serial Number: FTX1604M05C
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
Services
Service Name: Context Aware Service
Service Version: 7.0.200.204
Admin Status: Enabled
Operation Status: Up
Service Name: Wireless Intrusion Protection Service
Service Version: 1.0.2077.0
Server Monitor
Server start time: Fri Jul 13 13:30:25 BST 2012
Server current time: Fri Jul 13 13:31:06 BST 2012
Server timezone: GB-Eire
Server timezone offset: 0
Restarts: 22
Used Memory (bytes): 41991360
Allocated Memory (bytes): 158859264
Max Memory (bytes): 954466304
DB virtual memory (kbytes): 0
DB virtual memory limit (bytes): 0
DB disk memory (bytes): 1913046656
DB free size (kbytes): 0
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interfer
ers, Wired Clients): 0
Active Wireless Clients: 0
Active Tags: 0
Active Rogue APs: 0
Active Rogue Clients: 0
Active Interferers: 0
Active Wired Clients: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired C
lients, Tags) Limit: 1000
Active Sessions: 0
Wireless Clients Not Tracked due to the limiting: 0
Tags Not Tracked due to the limiting: 0
Rogue APs Not Tracked due to the limiting: 0
Rogue Clients Not Tracked due to the limiting: 0
Interferers Not Tracked due to the limiting: 0
Wired Clients Not Tracked due to the limiting: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Cl
ients) Not Tracked due to the limiting: 0
Context Aware Sub Services
Subservice Name: Aeroscout Tag Engine
Admin Status: Disabled
Operation Status: Down
Subservice Name: Cisco Tag Engine
[[email protected]-SR1-MSE-1 ~]# /etc/init.d/msed status
STATUS:
Server Config
Hw Version: V01
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Services
Server Monitor
Server current time: Fri Jul 13 13:41:33 BST 2012
Restarts: 22
Used Memory (bytes): 53046040
Allocated Memory (bytes): 192217088
Active Tags: 0
Active Rogue APs: 0
Active Sessions: 0
Has anybody else experienced these problems that can help, or could someone help with trouble shooting it.
Many Thanks
Simon
Scott Fella Fri, 07/13/2012 - 20:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Simon,
Try to swap the gigabit port on the MSE.... from the MSE, you should be able to ping the NCS also.
Amjad Abdullah Sat, 07/14/2012 - 04:38
  • Red, 2250 points or more
Make sure port 16113 is not blocked between NCS and MSE. Do you have a firewall between the two appliances?
The TCP port (16113) that the controller and mobility service communicate over MUST be open (not blocked) on any firewall that exists between the controller and mobility service for NMSP to function.
Reference: http://www.cisco.com/en/US/docs/wireless/ncs/1.0/configuration/guide/mse.html
Amjad
Scott Fella Sat, 07/14/2012 - 06:17
  • Hall of Fame,
    2017 Wireless
When you said this:
Are you saying that when the MSE is connected you can't ping the MSE from the WCS or vice versa? Can you ping the gateway of the MSE when consoled from the MSE? The issue with the MSE is that depending on what network port the MSE brings up first during the boot up, that will be the active interface. Also the mse script does not work too well. After you run the initial script in the MSE you need to restart the network services.
/etc/init.d/network restart
Enter the following commands after you complete the startup wizard. This is an example. You will hard set your gateway and the Mac address to eth0 port. This way eth0 will have that ip address all the time and the OS will not have a decision on what interface will have that ip address.
echo GATEWAY=10.7.6.1 >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo HWADDR=00:1E:67:15:B8:59 >> /etc/sysconfig/network-scripts/ifcfg-eth0
ifconfig eth0
Verify the configuration for eth0
Check system status
start|stop|restart|reload|status
s.vosper Thu, 07/19/2012 - 01:56
Hi guys
Scott - Thanks for responding. I have tried the things you have suggested but with no success. I can confirm IP connectivity because I can ping the NCS from the MSE itself. I have also tried restarting the MSE services.
Amjad - I have put the question to the customer regarding any firewalling that might be going on between the 2 and am awaiting a responce. My gut feeling is that there is no firewall between the 2 devices.
Any other ideas, because this is a real head scratcher for me
Many thanks
SImon
Scott Fella Thu, 07/19/2012 - 05:42
  • Hall of Fame,
    2017 Wireless
This is a new setup right? Well during the startup wizard, did you happen to change the WCS communication login and password? If so, rerun the wizard and when it comes back to the WCS communication credentials, press "D" which is default.
Scott Fella Thu, 07/19/2012 - 06:53
  • Hall of Fame,
    2017 Wireless
In case you need to run the startup wizard again, it will keep your existing entries unless you want to change it or use default.
/opt/mse/setup/setup.sh
Reginald Pugh Mon, 07/23/2012 - 15:56
What type of browser are u using if chrome try explorer then Firefox
Related Content
Trending Topics - Security & Network
