Warning message
how to know the memeory of the router ?
Answered Question
Jul 14th, 2012
hi , if i type the command sh ver :
917504K/65536K bytes of memory.
wts the meaning of the output ???
why it is as number/number ??
wt does that  mean & how to calculate the memory value of the router ??
should i sum the two number and divide by 1000 and the result will be memroy in mega ??
regards
Correct Answer by Reza Sharifi about 5 years 1 month ago
Hi Ahmed,
The first number is how much memory there is available for software, and the second number is how much memory there is available for I/O.  To get the megabyte, you add both numbers together and than divided by 1024.
917504K+65536K/1024=960.
So, you have approximately a gig of memory
Correct Answer by soroushm about 5 years 1 month ago
Hi Ahmed,
yes you have to sum both values and get the total. DRAM is divided logically, combining the two numbers determines total DRAM.
Cisco <platform-processor-type> processor (revision <processor-revision-id>) with
<free-DRAM-memory>K/<packet-memory>K bytes of memory.
this link could help you (scroll down to see examples):
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_s4.html#wp1499591
Hope it Helps,
Soroush.
Overall Rating: 5 (2 ratings)
Correct Answer
soroushm Sat, 07/14/2012 - 11:32
  • Gold, 750 points or more
Hi Ahmed,
Hope it Helps,
Soroush.
Ahmed M Alzaeem Sat, 07/14/2012 - 12:48
hi ,
thanks for the document,
i summed the two vlaues but the result is
983
so  wts my real memory value ??
960 or 1024 ???
regards
Correct Answer
Reza Sharifi Sat, 07/14/2012 - 13:30
  • Cisco Designated VIP,
    2017 LAN
Hi Ahmed,
Ahmed M Alzaeem Mon, 07/23/2012 - 03:45
hi mr reza
im facing unlogical problem in my router im using 7206
as u said that the memory above is 960
but i read from cisco navigator tool that my   ios need at least l024
does this issue may cause a conflict ? or i can ssume that my memroy is 1024  and forgte any problems from the ios ??
here is the ios requirements  form cisco
Image Name   c7200p-adventerprisek9-mz.124-24.T4.bin DRAM / Min Flash   1024 / 256 Enterprise Product Number   S72PAESK9-12424T
as u see it needs 1024 , but my config ram is 960
does this affect on the system?
regards
Joseph W. Doherty Mon, 07/23/2012 - 07:36
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
From your stats, believe you have 1GB RAM, so you should be okay.
Related Content
