Warning message
VoIP session filling up ports on PRI and VWIC-1MFT
Jul 14th, 2012
I'm having a problem with getting occassional busy signals on my IP  PBX. I've narrowed the problem down and occassionally I get duplicate  ports being consumed on a single call. With only 1 RTP session I can get  up to 9 channels consumed on my PRI.  I have verified the cable used is  correct per the adtran manual and cisco manual for the VWIC-1MFT  (crossover PRI pins 12 45 and tests ok on the cable certifier). Problem  appears to be completely random and I have not been able to duplicate  it. I have verifiedthe PBX has only 1 SIP/RTP session between the itself  and the VoIP phone. It appears to be occurring on the Cisco 1751-V. For  Privacy I have edited he calling party and destination numbers to  correspond with the call. I'm wondering if someone a bit more  experienced can help point me in the right direction of what to check  next because Im at a loss.
Version:
(C1700-IPVOICEK9-M), Version 12.4(15)T10
Network is setup as follows.
PSTN > Channelized DS3 > Adtran 890 <-PRI-> Adtran 550 <-PRI-> Cisco 1751-V <-IP/Ethernet-> IP-PBX
>sh run | begin int
interface FastEthernet0/0
ip address 10.10.10.10 255.255.255.0
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.10.10
interface Serial0/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
isdn supp-service name calling
isdn negotiate-bchan
no isdn outgoing display-ie
no cdp enable
voice-port 0/0:23
no vad
no comfort-noise
dial-peer voice 7 pots
preference 1
destination-pattern .
direct-inward-dial
port 0/0:23
forward-digits 10
dial-peer voice 700 voip
preference 1
session protocol sipv2
session target ipv4:10.10.10.11:5065
session transport udp
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs5 media
no vad
****PROBLEM CALLS****
>sh voice call sum
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/0:23.1        -          -  -
0/0:23.2        -          -  -
0/0:23.3        -          -  -
0/0:23.4        -          -  -
0/0:23.5        -          -  -
0/0:23.6        -          -  -
0/0:23.7        -          -  -
0/0:23.8        -          -  -
0/0:23.9        -          -  -
0/0:23.10       -          -  -
0/0:23.11       -          -  -
0/0:23.12       -          -  -
0/0:23.13       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.14       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.15       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.16       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.17       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.18       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.19       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.20       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.21       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.22       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0:23.23       g711ulaw   n  S_CONNECT             S_TSP_CONNECT
>sh voip rtp conn
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP LocalIP         RemoteIP
1   27651      27652      18364    24070  10.10.10.10    10.10.10.11
2   27662      27661      17992    16806  10.10.10.10    10.10.10.11
Found 2 active RTP connections
>sh isdn active
                                ISDN ACTIVE CALLS
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
Out  0000000001  XXXXXXXXXX                    17       0       0      0
Out  0000000002  XXXXXXXXXX                    15       0       0      0
In     0000000002  XXXXXXXXXX                    15       0       0      0
****Normal Call****
>sh voice call sum
0/0:23.1        -          -  -
0/0:23.2        -          -  -
0/0:23.3        -          -  -
0/0:23.4        -          -  -
0/0:23.5        -          -  -
0/0:23.6        -          -  -
0/0:23.7        -          -  -
0/0:23.8        -          -  -
0/0:23.9        -          -  -
0/0:23.10       -          -  -
0/0:23.11       -          -  -
0/0:23.12       -          -  -
0/0:23.13       -          -  -
0/0:23.14       -          -  -
0/0:23.15       -          -  -
0/0:23.16       -          -  -
0/0:23.17       -          -  -
0/0:23.18       -          -  -
0/0:23.19       -          -  -
0/0:23.20       -          -  -
>sh voip rtp conn
2   27676      27675      18780    22516  10.10.10.10     10.10.10.11
3   27678      27677      16398    32766  10.10.10.10     10.10.10.11
Found 3 active RTP connections
>sh isdn active
                                ISDN ACTIVE CALLS
Out  0000000001  XXXXXXXXXX                   207       0       0      0
In     0000000002  XXXXXXXXXX                    46       0       0       0
In     0000000003  XXXXXXXXXX                    17       0       0       0
cgitech.jonlenn Tue, 07/17/2012 - 08:57
I have verified everything I know and still nothing turning up, no errors, no alarms, nothing. So I'm now leaning towards a bad piece of equipment since I have similarly setup gateways in use and they are not suffering from the issue. I'll start replacing the cards, DSPs, and ultimately the chassis and see what happens.
Related Content
