How to remove Static NAT from cisco 3845
Jul 14th, 2012
Dear boss
I am using  cisco (C3845-ADVIPSERVICESK9-M), Version 12.4(11).  some static nat is configured. Now i want to remove all nat and configure again.
i am using router# clear ip nat translation *
                router (conf) # no ip nat .......... but no enty is beign delating.
How to detate all nat or single nat ????????
shahid
Sandeep Choudhary Sun, 07/15/2012 - 02:07
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
To remove old NAT settings on Cisco router you need to
1)Clear all old NAT translations
router#clear ip nat translatiom *
2)Disable old NAT pool settings
router(config)#no ip nat pool public_access 200.100.10.33 netmask 255.255.255.252
3)And finally, disable the translation:
router(config)#no ip nat inside source list 1 pool public_access overload
From this point you can safely configure the new NAT settings.
or use this link:
http://www.phirebird.net/2009/07/cant-remove-ip-nat-entries-on-cisco-router-static-entry-in-use-cannot-remove/
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094422.shtml
Cheers.
shahid_duet Sun, 07/15/2012 - 02:19
Mr. sandeep
My nat is: ip nat inside source static 0.0.0.0 0.0.0.0
i did  : router # no ip nat translation *
          router(conf) # no ip nat inside source static 0.0.0.0 0.0.0.0
          router ( conf-in)# no ip nat outside
but nat is not deleting.  i alos reboot the router.
Still nat exist. what can i do now ????
Shahid
Sandeep Choudhary Sun, 07/15/2012 - 02:20
    2017 Wireless
have you deleteed the ip nat inside or outside from the interface configs????
shahid_duet Sun, 07/15/2012 - 02:26
mr. sandeep
yes. i deleted  ip nat inside or outside from all interface and tunnel
shahid
eddie.moore1058 Wed, 05/31/2017 - 12:17
1st Q: when you did the "no ip nat...." did you do a "sh run | i nat" to see if the command took?
2nd Q: when you reboot the rtr, did you save config or no?
eddie.moore1058 Wed, 05/31/2017 - 12:19
I guess I should check dates on topics to see when they were posted.  5 years ago... this should have been resolved by now.  LOL!!!  Sorry, 1st and 2nd post from a newB on this forum.
Related Content
