Warning message
ISE CoA clarification
Jul 15th, 2012
Hi everyone--trying to make sense of ISE licensing and what a client of mine is wanting to accomplish. They want to be able to do dot1X and have the machine authenticate via AD before the user even tries to authenticate and if it's not a domain machine, then do a reject access. My question is that able to be accomplished via base licensing or is that considered posturing/profiling?
Thanks all!
SJ
Overall Rating: 5 (1 ratings)
Tarik Admani Sun, 07/15/2012 - 11:13
  • Green, 3000 points or more
Scott,
Hi the requirement that you are requesting will work under the base feature set. You do not need advanced and coa is not required to make this work. You can build your authorization policies such that user authentications must pass a check for a previou successful machine authentication.
Tarik Admani
Please remember to rate helpful posts!
Venkatesh Attuluri Tue, 05/28/2013 - 02:32
  • Cisco Employee,
advanced licence is not recquired to acomplish this task .authorization policy can be used for this
Naveen Kumar Tue, 02/04/2014 - 01:14
  • Silver, 250 points or more
Base license is sufficient for this.
Related Content
