Warning message
AP 1242 shows WLC's management ip as it's own ip address
Jul 15th, 2012
Dear All,
              we are using wism 4404 code 4.2 , we are using this old code becuase of 1250 mesh APs, now when a user connect to our network and he is using intel proset software he can see details of our AP, like mac, type and AP ip address 9 which in this case it the controllers ip address) is there a way we can prevent the ap from showing it?...we will be doing an upgrade to 7.0.230 soon. will the upgrade takes care of this problem or there is a way to fix it.
thanks a lot you guys
Scott Fella Sun, 07/15/2012 - 10:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Disable aironet ie in the WLAN SSID advanced tab. That should do it.
Leo Laohoo Sun, 07/15/2012 - 15:14
  • Hall of Fame,
    2017 LAN, Wireless
Go to 7.0.235.0 instead.
Sufian allan Sun, 07/15/2012 - 21:35
Thanks guys for the quick reply,
i disabled the Aironet IE for the ssid, and only the AP name disappeard but not the IP address, also we have a teat controller that runs code 7.0.230 and its doing the same thing, were i can see the ip address , but not the AP name.
any fix for this.?
Thanks and regards.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
