ASA 8.4 NAT not working
Jul 16th, 2012
Could someone explain why my ASA config does not work? My config is attached in a txt file.
I tried to forward port 25 and 110 from the outside to the inside server, but I can't connect...
I starting to get gray on this issue...
varrao Mon, 07/16/2012 - 06:27
  • Red, 2250 points or more
Hi Tim,
You need to apply the access-group:
access-group outside_access_in in interface outside
It should work after that.
Varun Rao
Security Team,
Cisco TAC
Tim Roelands Mon, 07/16/2012 - 09:16
Thanks for your response!
I really start to doubt my ISP, because I can still not connect to the site with a:
telnet *wanIP* 110
No reponse
I can ping the local server (192.168.1.10) from the ASA CLI...
Tim Roelands Mon, 07/16/2012 - 12:19
ISP answered that all ports are open and usable...I'm confused now...
Karsten Iwen Mon, 07/16/2012 - 23:54
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
in your original config are wrong objects. You define the object as server1_pop3, but configure NAT for server1_https:
object network server1_pop3
  host 192.168.1.10
object network server1_https
  nat (inside,outside) static interface service tcp pop3 pop3
After correcting that (and following Varuns advice for applying the ACL) it really should work.
Tim Roelands Tue, 07/17/2012 - 01:20
I'm so sorry, but it still doesn't work. Here is my running config after applying the changes:
WAN IP:               95.*.*.218 255.255.255.248
ASA IP:               192.168.1.253 /24
Smtp / Pop IP:     192.168.1.10 /24
I can ping 192.168.1.10 from the ASA CLI. I can Ping DNS 4.2.2.2 from the CLI. I can Telnet the server from the inside LAN, using: telnet 192.168.1.10 110.
But I can't Telnet from an outside location using: Telnet 95.*.*.218 110
ASA Version 8.4(3)
hostname ciscoasa
enable password cE8CBbDs encrypted
passwd 2KFQnbN encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.253 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 95.*.*.218 255.255.255.248
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network server1_smtp
host 192.168.1.10
host 192.168.1.10
access-list outside_access_in extended permit tcp any host 192.168.1.10 eq smtp
access-list outside_access_in extended permit tcp any host 192.168.1.10 eq pop3
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp smtp smtp
route outside 0.0.0.0 0.0.0.0 95.*.*.217 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
client-update enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:45efca6ddb136bc3aa7be64e0e733608
varrao Tue, 07/17/2012 - 04:39
Hi Tim,
Can you please give this a try, I guess it should work:
Remoe the existing nat and then add:
object service tcp_smtp
  service tcp destination eq 25
object service tcp_pop3
  service tcp destination eq 110
nat (outside,inside) source static any any destination static interface server1_smtp service tcp_smtp tcp_smtp
nat (outside,inside) source static any any destination static interface server1_pop3 service tcp_pop3 tcp_pop3
Let me know if it works.
Varun Rao
Security Team,
Cisco TAC
Tim Roelands Tue, 07/17/2012 - 05:08
Like this:
ASA Version 8.4(3)
hostname ciscoasa
enable password cE8CBbDsv encrypted
passwd encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
host 192.168.1.10
host 192.168.1.10
service tcp destination eq smtp
service tcp destination eq pop3
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:67e389016172f43c03293912765d3741
varrao Tue, 07/17/2012 - 05:09
Absolutely...
Varun Rao
Security Team,
Cisco TAC
Tim Roelands Tue, 07/17/2012 - 05:35
Pff, still no go...I can't understand why... Maybe a packet trace is usefull?
First picture is from my message : Jul 17, 2012 10:20 AM
Second Picture after the change made on: Jul 17, 2012 2:08 PM
Maybe that can help?
Jouni Forss Tue, 07/17/2012 - 05:51
You need to use the actual public IP address as the destination address and not the private/local IP.
The CLI version of the packet-tracer command would be easier to look through at since you can just copy paste the result to the post here on the forums
- Jouni
varrao Tue, 07/17/2012 - 05:53
Use this:
packet-tracer input outside tcp 1.1.1.1 23456 25 detailed
Varun Rao
Security Team,
Cisco TAC
Tim Roelands Tue, 07/17/2012 - 06:31
Could you please a bit more explicite Varun?
Should the command look like this?
packet-tracer input outside tcp 192.168.1.10 25 95.*.*.218 25 detailed
Thanks!
varrao Tue, 07/17/2012 - 10:15
Hi Tim,
You have the wronmg packet-tracer command, sorry I could not find time earlier as I was on my way back home, here's the right one:
packet-tracer input outside tcp 1.1.1.1 23456 95.*.*.218 25 detailed
you are testing the connection for any internet IP coming from any random port, for which you have 1.1.1.1 & 23456
Varun Rao
Security Team,
Cisco TAC
deyster94 Thu, 07/19/2012 - 07:04
Can you post a screen shot of how your nat statements look in ASDM?  I have seen on more than one occasion that the order that the NAT statements are in have screwed things up.
Tim Roelands Thu, 07/19/2012 - 07:21
Hi! Thanks for your help!
After applying the following NAT and Access commands to the ASA:
host 192.168.1.10
host 192.168.1.10
access-list outside_access_in extended permit tcp any host 192.168.1.10 eq 25
access-list outside_access_in extended permit tcp any host 192.168.1.10 eq 110
ASDM looks like this:
In a second attempt applying this commands:
host 192.168.1.10
host 192.168.1.10
Both options fail....
deyster94 Thu, 07/19/2012 - 07:47
The first screenshot of the ASDM has the nats configured correctly.  However, I don't see a dynamic pat for regular internet access.  I don't think this would cause an issue, but you never know.  To allow internet access, you would need the following command:
nat (inside,outside) source dynamic 'internal-networks' interface.  Change the 'internal-networks' to a group object with your internal networks in it.
Tim Roelands Thu, 07/19/2012 - 10:26
Like:
nat (inside,outside) source dynamic internal interface
Tim Roelands Thu, 07/19/2012 - 13:09
Sorry m8, it did not..
ciscoasa# packet-tracer input outside tcp 1.1.1.1 23456 95.*.*.218 25 detai$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xd9027508, priority=1, domain=permit, deny=false
        hits=20, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=outside, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   95.*.*.218   255.255.255.255 identity
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xd9027b88, priority=0, domain=permit, deny=true
        hits=17, user_data=0x9, cs_id=0x0, use_real_addr, flags=0x1000, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
deyster94 Thu, 07/19/2012 - 13:12
Do you at least have internet access on the internal devices?  Also, in the ASDM, if you fire up the real time log monitor and then try to telnet to port 110 from outside of your network, does it give you any information?  Like what ACL is blocking the connection?
Tim Roelands Fri, 07/20/2012 - 06:06
Hi deyster94,
I have internet connectivity, tested.
Please exam the following, when I apply the following NAT rules:
host 192.168.1.10
host 192.168.1.10
This results in the following packet trace:
*.*.*.69 is the WAN IP from where I try to connect to the firewall over port 110 (telnet *.*.*.69 110).
95.*.*.218 is the WAN IP of the firewall. A said, I have internet connection from the inside network. I can ping 192.168.1.10. From within the Inside network telnet 192.168.1.10 110 works!
This looks like port 110 goes trough the firewall, but I can't still not connect from an external site to the internal server. Any suggestions?
deyster94 Fri, 07/20/2012 - 06:19
Tim,
I do my outside to inside nats different than how you them configured.  You can do a nat to an inside address from the object group.  Here is an example:
host 10.0.0.4
nat (INSIDE,OUTSIDE) static interface
You can do this in the ASDM on the object.  If you edit the object and click advanced, it will show you more options where you can configure the public IP address and do a PAT as well.
Have you tried this route yet?
Dan
Tim Roelands Fri, 07/20/2012 - 07:59
When my NAT looks like this: (seems like your way of setting NAT up)
Packet Trace looks like this:
My configfile looks like this: (nat (inside,outside) source dynamic internal interface) added
ASA Version 8.4(3)
hostname ciscoasa
enable password cE8CB encrypted
passwd 2KFQn encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
host 192.168.1.10
host 192.168.1.10
object network internal
subnet 192.168.1.0 255.255.255.0
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:c0bbf3c1c0d4c02400a1a18e2179e3fb
: end
deyster94 Fri, 07/20/2012 - 08:13
What happens if you change the source port on your packet trace to something 1024 or greater?  Also, if you click on the + next to access-list, what does it say?  This should tell you what ACL is blocking the traffic.
Tim Roelands Fri, 07/20/2012 - 10:44
That results in this packet trace:
Thanks for your help sofar!
deyster94 Fri, 07/20/2012 - 10:51
Tim,
I noticed this statement:
I would remove that since you already have this one:
The reason I am suggesting removing that is because of where it lies in the nat order.  Even though it is at the bottom in the ASDM, it is as the top in the config.  That may be causing this issue.
Dan
Tim Roelands Fri, 07/20/2012 - 12:33
Still the same issue in the packet trace, same error as in image:
My config now looks like:
ASA Version 8.4(3)
hostname ciscoasa
enable password cE8CBbDsvd encrypted
passwd 2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
host 192.168.1.10
host 192.168.1.10
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:5cee770b5ae708fc7de15292aabeea9a
deyster94 Fri, 07/20/2012 - 12:51
Alright, this is going to drive me nuts until I figure this one out.  I have an ASA5505 at home that has the same code and only one IP address as well.  Let me do some testing and I will let you know what if I figure out.
deyster94 Fri, 07/20/2012 - 13:20
Ok, so I tried some things out on my home ASA.  For a test, I made the public IP address on my static nat 1.1.1.1.  I ran a packet trace and it worked fine.  I switched back to the interface and it fails like the packet trace you have posted above.  What is odd is that I know I used pat/nat to the interface in my ASA 5505.  I am starting to wonder if this is a bug in the newer code.  I can't remember if I was running pre-8.3 code when I did this before or not.
You may want to open a case with TAC and see what they have to say.  In the meanwhile, I am going to try to figure this out since it will effect companies that don't want to spend the money for more than 1 public IP address.  If there is a way to get more public IPs from your provider, it will fix your problem.
Tim Roelands Fri, 07/20/2012 - 14:44
I have more then one public IP! Should I downgrade the IOS you think?
deyster94 Mon, 07/23/2012 - 06:07
If you can use that other public IP for the nat to the server, I would just do that instead.  However, if you need that public IP address for something else, then downgrading would be an option.
Related Content
