Warning message
Can't get caller id to show on call waiting line on 7912G Phone
Jul 16th, 2012
                   I have CME 4.1 running on a 1760 with four 7912G phones. I have one of the phones setup for dual-line (ext 1001). When I call this phone from the other extensions, the caller id works fine. One caller id showing the first extension that called and the other caller id displays on the same phone (ext 1001) when the first line is in use and you call it from yet another extension. The problem is with incomming POTS lines calls. When you call into the dual line 7912 from the POTS line that is PLAR'd to it, the caller id displays the POTS number on the 7912. When you then call into this same 7912 from another POTS line, you hear the call waiting tone, but no caller id displays. What might be the problem?
voice-port 2/1
connection plar opx 1001
caller-id enable
ephone-dn  1  dual-line
number 1001
pickup-group 5000
name PHONE-1
call-forward busy 3000
call-forward noan 3000 timeout 20
corlist incoming use100
ephone  1
mac-address 0014.A923.BAE0
paging-dn 7
button  1:1
telephony-service
load 7912 CP7912080001SCCP051117A
max-ephones 4
max-dn 8
ip source-address 172.16.1.1 port 2000
voicemail 3000
mwi relay
max-conferences 4 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.23.4.10 port 2000
web admin system name fiero password fiero
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 100.
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
Related Content
