C150 The case application tried and failed 3 times...
mpuha
Hi All,
Requesting some help with the IronPort C150 Alert below. Thanks for any suggestions, pointers, or experience you can provide regarding this issue.
The Warning message is:
The case application tried and failed 3 times to successfully complete an update. This may be due to a network configuration issue or temporary outage.
Version: 7.5.1-102
Thank you,
--Liko
mpuha
Hi again,
Luckily I found this post which was not located using the search utility.
'CASE updates incorrectly timeout on 1U appliances'
--Liko
