07-16-2012 10:34 PM - edited 03-04-2019 04:59 PM
Hi everybody.
I have a cisco 1841 router which isn't able to boot properly from its IOS. it always prompt me on ROMMN.
Here it is:
System Bootstrap, Version 12.4(13r)T8, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0xd4a9a0
Self decompressing the image : ######################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 21135724 bytes to IO Memory.
PMem allocated: 239075328 bytes; IOMem allocated: 29360128 bytes
TLB (load or instruction fetch) exception, CPU signal 10, PC = 0x6020C48C
-Traceback= 0x6020C48C 0x6128D2B4 0x6128D350 0x6128C9A4 0x6128CBA4 0x6020D1B0 0x6056F1E0 0x6007ED54 0x8000FDC8 0x8000F9B8
$0 : 00000000, AT : 62370000, v0 : 00000000, v1 : 624A1240
a0 : 00000003, a1 : 00000001, a2 : 00000001, a3 : 62377820
t0 : 626D0FF4, t1 : 62700DFC, t2 : 62700DF8, t3 : 62700DF4
t4 : 62700DF0, t5 : 62700DEC, t6 : 62700DE8, t7 : 62700DE4
s0 : CE2B0000, s1 : 00FFFFFF, s2 : 7FFFFFFF, s3 : 62378840
s4 : 00000001, s5 : 62360000, s6 : 00000003, s7 : 624A1300
t8 : 62700E48, t9 : 00000000, k0 : 3041E801, k1 : 00100000
gp : 6237AF40, sp : 8000EC68, s8 : 00000000, ra : 6020C420
EPC : 6020C48C, ErrorEPC : 01068224, SREG : 3401C103
MDLO : 0000000D, MDHI : 023E5960, BadVaddr : CE2B0020
Cause 80000008 (Code 0x2): TLB (load or instruction fetch) exception
TLB (load or instruction fetch) exception, CPU signal 10, PC = 0x0
-Traceback=
$0 : 00000000, AT : 62370000, v0 : 00000000, v1 : 00000040
a0 : 621A3130, a1 : FFFFFFFF, a2 : 621A30BC, a3 : FFFFFFFF
t0 : 00000000, t1 : 00000000, t2 : 00000000, t3 : 00000000
t4 : 00000000, t5 : 0000000D, t6 : 023E5960, t7 : CE2B0020
s0 : 621A3008, s1 : 621A3130, s2 : 621A30BC, s3 : 00000000
s4 : 00000000, s5 : FFFFFFFF, s6 : 7FFFFFFF, s7 : 0000000A
t8 : 62700E48, t9 : 00000000, k0 : 624EF790, k1 : 00000020
gp : 6237AF40, sp : 621A2FE0, s8 : FFFFFFFF, ra : 608E2328
EPC : 00000000, ErrorEPC : 01068224, SREG : 34018003
MDLO : 00000000, MDHI : 00000008, BadVaddr : 00000000
Cause 00002008 (Code 0x2): TLB (load or instruction fetch) exception
Nested write_crashinfo call (2 times)
-Traceback=
$0 : 00000000, AT : 62370000, v0 : 62360000, v1 : 62478010
a0 : 00000002, a1 : 00000000, a2 : 00000000, a3 : 000F4240
t0 : 00000038, t1 : 34018001, t2 : 34018000, t3 : FFFF00FF
t4 : 60561810, t5 : 00002008, t6 : 00000000, t7 : CE2B0020
s0 : 0000000A, s1 : 00002008, s2 : 0000000A, s3 : 00000000
s4 : 00002008, s5 : 62530000, s6 : 00000038, s7 : 624F0000
t8 : 62700E48, t9 : 00000000, k0 : 624EF790, k1 : 00000038
gp : 6237AF40, sp : 621A2F00, s8 : 621A0000, ra : 6055D0BC
MDLO : 0001E848, MDHI : 00000000, BadVaddr : 00000000
Nested write_crashinfo call (3 times)
-Traceback=
-Traceback=
and it stops there with nothing. when I remove the Compact Flash, it prompt me on rommon.
If somembody have an idea what's happen , please help.
Thank you.
07-16-2012 11:27 PM
Hello Lova,
Did the same IOS image work on this router before? If yes and this error simply started suddenly appearing, it may suggest a problem with RAM modules. Try opening the router, remove and reseat the DRAM modules and see if this helps.
If you have another 1841 router available, perhaps it would be beneficial to try to boot this other router from your CF card to see if the card and the IOS stored on it is capable of booting properly in a different router, although I don't think this is the case, as the IOS image was unpacked with no problems during your boot.
Best regards,
Peter
07-19-2012 11:41 PM
Hi, thank you for your reply, Peter.
I also suspected the RAM module...is one from a laptop computer would be compatible? I have other 1841 but I can't stop them at this time to do a permutation so I manage to do that next time. The CF card was never removed and never modified. the router was runing on it till it down.
07-20-2012 12:54 AM
Hello Lova,
I have indeed heard about people being able to re-use laptop DRAM modules in Cisco routers. However, it is not without risks - while I suggest trying that out if possible, I strongly urge you to find (Google is your friend) as much information about the chips used on both Cisco and laptop DRAM modules as possible, with particular respect to the required voltage so that you don't burn out or underpower the laptop memory module.
Please let me know.
Best regards,
Peter
