Realtime statistics for Wallboards for UCCX 8.0
Answered Question
Jul 17th, 2012
For our client we have developed 2 Wallboard pages for UCCX 8.0 based Contact Centre, both the pages do a database dip every 2 secs.
Main Screen: Details on this screen is captured from RtCSQsSummary Table
Agent Status Screen: Details on this screen is captured from Resource / AgentStateDetail / ResourceSkillMapping / Skill  Tables
We have observed that the data seen on the Main Screen- Agent Status is not in sync with the data seen on the Agent Status Screen. If a State of the Agent changes on the Agent Status screen to Ready, the number of Ready Agents on the Main Screen is not reflected immediately. It takes almost 10-12 secs to reflect the changes on the Main Screen. We have checked the data by accessing the Database directly using Squirrel, the RtCSQsSummary table data takes longer to reflect the changes seen in the AgentStateDetail Table.
Does anyone know why the data in the RtCSQsSummary table takes longer to refresh than the AgentStateDetail table, is there any configuration which controls this?
Correct Answer by Aaron Harrison about 5 years 1 month ago
The rtCsqSummary table and the other rt table should update in accordance with the settings configured in 'Tools/Realtime Snap Shot Config'. Check that the interval there is set to 5 seconds as the default is 30.
If it is set to 5 and isn't updating properly, it's probably TAC-case-time.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
kiarash.kazemi Tue, 07/17/2012 - 06:35
Many thanks Aaron,
We will double check this and speak to TAC.
Kiarash
Correct Answer
Aaron Harrison Tue, 07/17/2012 - 05:27
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron Harrison
Related Content
