aaa new-model
Answered Question
Jul 11th, 2012
How this command works "aaa authentication enable default group radius"? I used Cisco Secure ACS 4.2 as my Radius Server but I can't login.. Is there somebody here can give me a thorough understanding on this command? Need this for my CCNA security exam.. Please help..
Additional INfo:
IETF Radius Attributes: NAS Prompt
here's my config on R1:
version 12.4
service password-encryption
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$e.TZ$EXkOaZ0rkd/GBGLA/8GrD/
aaa new-model
aaa session-id common
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name aida.com
ip ssh version 2
username mark privilege 15 password 7 110418171C
username anthony password 7 050A081B29434010
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 192.168.5.1 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.10.1 255.255.255.252
duplex auto
speed auto
router eigrp 100
network 1.1.1.1 0.0.0.0
network 10.10.10.0 0.0.0.3
network 192.168.5.0 0.0.0.7
no auto-summary
no ip http server
no ip http secure-server
radius-server host 172.16.178.3 auth-port 1645 acct-port 1646 key 7 xxxxxxxxxxxxxxxxxxxxxxxxxxx
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login local
transport input ssh
end
Correct Answer by Ramraj Sivagnan... about 4 years 9 months ago
Hi Mark
I have recreated the steps in my lab and I saw the same problem as you did. Please click on this URL https://www.yousendit.com/download/QlVqTmZhUENFc0t4djhUQw to download the steps on the Router/Switch portion and on the ACS portion. Please do follow the steps strictly. This is a small problem :-) I will help you.
If the steps provided still doesn't work, please paste your Router/Switch latest show running-config here. I'll verify that first before verifying your ACS config. Good luck bro!!
Hi Bro
The command "aaa authentication enable default group radius" means that, for your enable password, you want the Router to refer to the ACS server and obtain the credentials.
Another example, the command "aaa authentication enable default group radius enable" means that, for your enable password, you want the Router to refer to the ACS server and obtain the credentials. In the event your ACS is down, you want the Router to refer to the local enable password and obtain the credentials.
I saw what you're trying to achieve, and you can achieve this in RADIUS as well, but personally I prefer TACACS+ whenever possible.
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default local
radius-server host 10.0.0.100 auth-port 1645 acct-port 1646 key cisco123
Note: $enab15$ this is seen because you don't have aaa authorization commands configured. You can either add a dummy username $enab15$ in your ACS or you could paste the following commands shown below in your Router;
username admin privilege 15 password 0 cisco123
username operator privilege 7 password 0 cisco123
P/S: Please do rate this comment, if you find this feedback useful :-)
Overall Rating: 5 (3 ratings)
mactej6228 Fri, 07/13/2012 - 04:56
Please help.. Is there anyone here who can give me a thorough understanding on this command "aaa authentication enable default group radius"? How this command affect communicate w/ my radius server? I defined users in radius server, when I can used it? I use ssh..
Karsten Iwen Fri, 07/13/2012 - 05:14
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
There are a couple of options that are available. The best way for most environments is the following:
Migrate to TACACS+
With TACACS you have more control over your administration-sessions. If you want you can use TACACS+ and RADIUS at the same time for different functions (TACACS for ADMIN, RADIUS for VPN ...)
How to do that:
1) Configure your AAA-client on the ACS for TACACS
2) Configure a tacacs-server instead a RADIUS-server in IOS
3) use the following aaa-commands:
aaa authentication login default group tacacs
aaa authentication enable default group tacacs
Now your ACS-User is taken for initial login and for the enable. The Enable-password can be configured for individual users or for the usergroup that the user belongs to.
If your ACS is not reachable, you can also configure a fallback. For that you add another method to you aaa commands:
aaa authentication login default group tacacs local
aaa authentication enable default group tacacs enable
mactej6228 Fri, 07/13/2012 - 21:08
Thanks for your reply karsten, yes you right there I can migrate to TACACS+ but I must first understand on what is RADIUS server means, how does it handle defined users during authentication? That is why I need to understand the command.. This for the preparation of my CCNA security exam.. Need to understand the basics of the command which i specified above.. Thanks In Advance..
nkarthikeyan Sat, 07/14/2012 - 09:39
  • Gold, 750 points or more
Hi Mark,
Let me explain you about the radius and tacacs+.
Radius uses UDP port (1812,1813) or (1645-1646).
TACACS+ uses TCP 49 (Which is reliable.
RADIUS auth we use that for VPN, Web authentication, Wireless users like that
TACACS+ used for network devices/servers authentication.
Radius requires timeout and other options to be enabled to switchover/auto disconnecting the connection. It works in client server architecture... i.e handshake..,ppp.pap,chap.
Radius doesn't support few protocols.
  • AppleTalk Remote Access (ARA) protocol
  • NetBIOS Frame Protocol Control protocol
  • Novell Asynchronous Services Interface (NASI)
  • X.25 PAD connection
mactej6228 Sat, 07/14/2012 - 20:38
So why is it that I can't login on the router? When I login to privilege mode it ask me for username and password, I already tried the password configured on Radius server but still I can't login to privilege mode...
Karsten Iwen Sun, 07/15/2012 - 05:45
if you want to find out what the AAA-client does you can use the command "debug radius":
If I log into my switch which uses RADIUS then the switch askes for authentication of my used username:
Jul 15 12:20:50.565: RADIUS:  User-Name           [1]   14  "karsten.iwen"
When I enter "enable" and I have "aaa authentication enable default group radius" configured, then the switch doesn't use the real username, but the generic user:
Jul 15 12:40:03.876: RADIUS:  User-Name           [1]   10  "$enab15$"
That can't be handled by RADIUS, but with TACACS+
Correct Answer
Ramraj Sivagnan... Sun, 07/15/2012 - 23:10
  • Silver, 250 points or more
Hi Bro
aaa new-model
mactej6228 Mon, 07/16/2012 - 09:01
hi Karsten,
Thanks for your reply. Okay here's the output on "debug radius". I follow instruction of "Ramraj", so what's the problem here?
Karsten Iwen Mon, 07/16/2012 - 10:34
there you have the problem that your shared secrets don't match.
mactej6228 Mon, 07/16/2012 - 09:07
Thank You Ramraj. I follow your instruction but still I can't login. What do you mean by "$enab15$"? because what i have done I literally add that user to my ACS, I add there a user named "$enab15$" w/ a password of "cisco" but still won't log me in to my router  console. I performed the ff. command:
# aaa new-model
#radius-server host 172.16.178.3 key shared_secret
#aaa authentication enable default group radius
#aaa authorization exec default local
I also used the local username / password w/ privilege 15 on my router but still fails to authenticate.
Correct Answer
Ramraj Sivagnan... Mon, 07/16/2012 - 13:55
Hi Mark
mactej6228 Tue, 07/17/2012 - 10:01
Thank You Ramraj, really need your help. I follow your guides that you sent but still I can't login to privilege mode, here are some of configurations hope this can help...
https://supportforums.cisco.com/servlet/JiveServlet/download/3681152-131734/aaa_routerconfig.rar.zip
On my router config, I just made it simple because what I really wanted is to be able to get into privilege mode using the RADIUS server users. Thanks in Advance...
Ramraj Sivagnan... Tue, 07/17/2012 - 10:15
Hi Bro
I saw your Cisco Router's configuration, and you didn't put in the commands I advices in my previous post. Please paste them in and rerty again;
aaa authentication login VTY group radius local
aaa authentication login CONSOLE local
aaa authorization console
aaa authorization config-commands
aaa authorization exec VTY group radius local
line con 0
login authentication VTY
line aux 0
line vty 0 4
Lastly, could you change the Authenticate Using method to RADIUS (Cisco IOS/PIX 6.0) for R1. This is depicted in your captured file named ACS_AAA_Client.jpg.
mactej6228 Tue, 07/17/2012 - 22:18
okay I'm still at the office now later(9pm GMT +8)  when i got home i will install teamviewer at my homelab. I think we're in the same time zone. Thanks a lot bro.
Ramraj Sivagnan... Wed, 07/18/2012 - 07:50
Hi Bro
I believe everything is working fine now. If you find the above comments useful, please do rate them nicely :-)
Related Content
