How to backup the local phonebook/favorite in the C-series or EX-series with TC5.0
Arbenjamin
Dear all,
I would like to know it there any method to backup the local phonebook/favorite in the C-series or EX-series with TC5.0. On the other hand, we have configurated the root account.
We have found the local phone are stored with FolderId (localGroupId-3).
xCommand Phonebook Folder Add
Add a folder to the local phonebook, where phonebook entries can be stored. Returns the FolderId (localGroupId-3), which is a unique Id of the folder.
However, we want to the exact location of the FolderId (localGroupId-3), also, is it possible to backup such file in case we need to have a RMA.
Best Regards,
Ben
Martin Koch
Hello Ben!
Thats the benefit on centrazlied phonebooks, maybe Cisco could implement user based
phonebooks which are still centralized stored ...
Anyhow, I see at least two options, you can use the admin account tsh and execute:
xcommand Phonebook Search
    PhonebookId: < 0="">
    PhonebookType:
    SearchString: < 0="">
    SearchField:
    Offset: <0..65534>
    FolderId: < 0="">
    Limit: <0..65534>
    Recursive:
Maybe you need to use recursive or other options to get all entries.
Besides that it might be easier to just use the root account and scp to download the local
phonebook file and copy it over to an other endpoint, its location is:
/config/pb.xml
Please rate the anwer using the stars below and set the thread to answered if it is.
Martin
Martin Koch
Hello Ben!
    PhonebookType:
    SearchField:
    Offset: <0..65534>
    FolderId: < 0="">
    Limit: <0..65534>
    Recursive:
/config/pb.xml
Martin
Dear Martin,
Thank for your clear explaination!!!!
I have tried in my lab, it works fine.
We have rated your answer, it is a excellant solution !
Best Regards,
Ben
