How to seperate traffic over 2 lines using 2811's
Answered Question
Jul 17th, 2012
Here is our setup:
We have 2 locations. They are connected by a T1 and a new 10 meg fiber connection. Location 1 is the main site. Location 2 gets it's internet, voip, and data over these lines. I have successfully split the traffic going from location 2 to location 1. Here is location 2's 2811 config:
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description Interface for VLAN 1
encapsulation dot1Q 1 native
ip address 10.1.3.6 255.255.255.0
no snmp trap link-status
interface FastEthernet0/0.2
description Interface for VLAN 2
encapsulation dot1Q 2
ip address 192.168.30.5 255.255.255.0
interface FastEthernet0/0.4
description Interface for VLAN 4
encapsulation dot1Q 4
ip address 10.10.11.1 255.255.255.0
interface Serial0/0/0
bandwidth 1540
ip address 10.10.3.1 255.255.255.252
encapsulation ppp
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
service-module t1 timeslots 1-24
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.11.2
ip route 10.1.1.0 255.255.255.0 10.10.3.2
ip route 10.1.2.0 255.255.255.0 10.10.3.2
ip route 192.168.20.0 255.255.255.0 10.10.3.2
ip route 192.168.254.0 255.255.255.0 10.10.3.2
So all internal traffic is going over the T1 (10,10.3.2) and all internet by default is going over the Fiber line (10.10.11.2) The question that I have is related to Site 1. Going back over to Site 2, I want to do the same thing. I want all internal data (10.1.3.0, VOIP etc) to go over the T1, and I want internet traffic to go over the Fiber line (10.10.11.1) Here are the routes for Site 1:
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.2.1
ip route 10.1.1.0 255.255.255.0 10.10.1.1
ip route 10.1.3.0 255.255.255.0 10.10.11.1
ip route 192.168.20.0 255.255.255.0 Serial0/0/0
ip route 192.168.30.0 255.255.255.0 10.10.11.1
With this current setup, all traffic, internet and data are going over the fiber line (10.10.11.1) There must be a way to direct all data over the T1 (10.10.3.2) and have all internet traffic go back over the fiber line (10.10.11.1). So that is the question, how can this be accomplished.
Here are the networks involved:
10.1.2.0 and 192.168.254.0 are Site 1
10.1.3.0 and 192.168.30.0 are Site 2
There is a site 3 that I will eventually clone this model after, as soon as I can get it working. Thanks for any assistance that is out there and please let me know if there are any questions!
Correct Answer by cadet alain about 4 years 10 months ago
yes this was what I was referring to.
ok so can you post a traceroute output for both destinations( data and internet) from the router and from a host.
Regards.
Alain.
Overall Rating: 5 (6 ratings)
cadet alain Wed, 07/18/2012 - 00:32
  • Purple, 4500 points or more
can you post output of sh ip int br and sh ip route on site1.
Regards.
Alain.
worthingtontech Wed, 07/18/2012 - 03:44
Thank you for the reply Alain. Here is the information you requested:
sh ip int br:
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/0.1          10.1.2.3        YES NVRAM  up                    up
FastEthernet0/0.2          192.168.254.5   YES NVRAM  up                    up
FastEthernet0/0.3          unassigned      YES NVRAM  deleted               down
FastEthernet0/0.4          10.10.11.2      YES manual up                    up
FastEthernet0/1            10.10.20.1      YES NVRAM  up                    up
Serial0/0/0                10.10.1.2       YES NVRAM  up                    up
Serial0/1/0                10.10.3.2       YES NVRAM  up                    up
Serial0/2/0                unassigned      YES NVRAM  administratively down down
The FE0/0.3 and Serial0/2/0 are not in use.
sh ip route:
Gateway of last resort is 10.1.2.1 to network 0.0.0.0
     192.168.62.0/32 is subnetted, 1 subnets
S       192.168.62.1 [1/0] via 10.10.20.2
S    192.168.30.0/24 [1/0] via 10.10.11.1
S    192.168.20.0/24 is directly connected, Serial0/0/0
     10.0.0.0/8 is variably subnetted, 10 subnets, 3 masks
C       10.10.1.1/32 is directly connected, Serial0/0/0
C       10.10.1.0/30 is directly connected, Serial0/0/0
C       10.10.3.1/32 is directly connected, Serial0/1/0
C       10.10.3.0/30 is directly connected, Serial0/1/0
S       10.1.3.0/24 [1/0] via 10.10.11.1
C       10.1.2.0/24 is directly connected, FastEthernet0/0.1
S       10.1.1.0/24 [1/0] via 10.10.1.1
C       10.10.11.0/24 is directly connected, FastEthernet0/0.4
C       10.10.20.0/30 is directly connected, FastEthernet0/1
S       10.76.0.0/30 [1/0] via 10.10.20.2
C    192.168.254.0/24 is directly connected, FastEthernet0/0.2
S    192.168.220.0/24 [1/0] via 10.10.20.2
S*   0.0.0.0/0 [1/0] via 10.1.2.1
10.1.2.1 is our Firewall at Site 1. Let me know if there is more information needed. Thank you.
cadet alain Wed, 07/18/2012 - 04:41
Are you using any Policy-based routing on this router?  sh run | s route-map
Regards.
Alain.
Correct Answer
cadet alain Thu, 07/19/2012 - 00:12
Regards.
Alain.
worthingtontech Thu, 07/19/2012 - 07:26
Here are the 2 site networks: 10.1.2.1 (Site 1) 10.1.3.6 (Site 2)
Trace from Site 2 to Site 1 Data
Tracing the route to 10.1.2.71
1 10.10.3.2 8 msec 4 msec 8 msec
2 10.1.2.71 4 msec 8 msec 4 msec
Trace from Site 2 to Site 1 Internet
Tracing the route to 173.194.73.106 (google)
1 10.10.11.2 4 msec 4 msec 0 msec
So data is going from site 2 to site 1 over the T1 (10.10.3.2) and internet is going over the Fiber line (10.10.11.2)
Trace from Site 1 to Site 2 Data
Tracing the route to 10.1.3.6
1 10.10.11.1 0 msec * 0 msec
Trace from Site 1 to Site 2 Internet
Tracing route to google.com [74.125.225.46]
over a maximum of 30 hops:
1     1 ms   <1 ms   <1 ms 10.1.2.3
So data is going from site 1 to site 2 over the fiber, and Site 1 internet (which is the main site for the fiber) goes out over a different fiber line (10.1.2.3 is our firewall). If I route all the data for the internal networks over the T1, the internet download at Site 2 becomes 1.5 meg, the T1 speed. So there is my dilemma. I need to get data going back over the T1 to site 2 but I need the internet for Site 2 to go back over the Fiber line. I hope that makes sense. Thanks!
cadet alain Mon, 07/23/2012 - 01:12
can you post a diagram along with configs from both sites.
Regards.
Alain.
worthingtontech Mon, 07/23/2012 - 05:45
Thank you very much for taking an interest in this Alain. Here is the requested information. (I am aware there are some extraneous lines in the routers...we are eventually switching our 2811's to 2911's):
Site 1 config:
class-map match-any AutoQoS-VoIP-Remark
match ip dscp ef
match ip dscp cs3
match ip dscp af31
class-map match-any AutoQoS-VoIP-Control-UnTrust
match access-group name AutoQoS-VoIP-Control
class-map match-any AutoQoS-VoIP-RTP-UnTrust
match protocol rtp audio
match access-group name AutoQoS-VoIP-RTCP
policy-map AutoQoS-Policy-UnTrust
class AutoQoS-VoIP-RTP-UnTrust
  priority percent 70
  set dscp ef
class AutoQoS-VoIP-Control-UnTrust
  bandwidth percent 5
  set dscp af31
class AutoQoS-VoIP-Remark
  set dscp default
class class-default
  fair-queue
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
no ip address
duplex auto
speed auto
ip address 10.1.2.3 255.255.255.0
ip address 192.168.254.5 255.255.255.0
ip address 10.10.11.2 255.255.255.0
interface FastEthernet0/1
description connection to CML router
ip address 10.10.20.1 255.255.255.252
duplex auto
speed auto
bandwidth 1540
ip address 10.10.1.2 255.255.255.252
ip nbar protocol-discovery
encapsulation ppp
auto qos voip
service-module t1 clock source internal
ppp authentication chap
service-policy output AutoQoS-Policy-UnTrust
interface Serial0/1/0
bandwidth 1540
ip address 10.10.3.2 255.255.255.252
encapsulation ppp
tx-ring-limit 26
tx-queue-limit 26
auto qos voip
no keepalive
interface Serial0/2/0
no ip address
encapsulation ppp
shutdown
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ip classless
ip http server
ip http authentication local
no ip http secure-server
ip access-list extended AutoQoS-VoIP-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
ip access-list extended AutoQoS-VoIP-RTCP
permit udp any any range 16384 32767
Site 2 config:
match ip dscp ef
match ip dscp cs3
match ip dscp af31
  priority percent 70
  set dscp ef
  bandwidth percent 5
  set dscp af31
  set dscp default
class class-default
  fair-queue
no ip address
duplex auto
speed auto
no ip address
duplex full
speed 100
bandwidth 1540
encapsulation ppp
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
no ip address
encapsulation ppp
shutdown
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ip classless
cadet alain Mon, 07/23/2012 - 22:55
Hi Darren,
I won't have the time to look at your configs today but I'll do it tomorrow but maybe someone else will already have found the solution in the meantime.
Regards.
Alain.
worthingtontech Tue, 07/31/2012 - 07:21
Hi Alain,
   I was just wondering if you had a chance to look this over. I'm going to start researching and working on the PBR solution with access list, but any assistance you can provide would be much appreciated. Thanks!
cadet alain Tue, 07/31/2012 - 10:54
not yet unfortunately, I'm very busy for the time being and I only spend a few time on CSC forums these days but normally I should have more time tomorrow. But if it's not working with the static routes then why should it work with PBR and anyway
PBR is for src-dst routing but this is not your case, what you want to achieve is assymetric routing( data coming on one link go back on another) ?
Regards.
Alain
worthingtontech Wed, 08/22/2012 - 04:46
After working with Cisco, I was able to get the correct routing statements. It was PBR, with a routing map that made the next hop the T1. If anyone wants the appropriate lines of code, let me know. Thanks! And thank you very much cadet alain. I appreciate the time you spent in this thread and pointing me in the right direction.
