Warning message
CTI OS Dektop Login Failure
Jul 17th, 2012
Hi All,
I have CTI OS dektop client and I have mentioned the CTIOS A and CTIOS B during installation. I have added the IP address of the CTIOS server details in the host file entry as well    ,
but still I vouldn't login and I see this issue,
7/17/12 15:43:54.961  6104  CTIOSSoftphone  Thd(5320)  Attempting to resolve hostname [snitswducspg1b] to IP address (gethostbyname).
07/17/12 15:43:57.610  6104  CTIOSSoftphone  Thd(5320)  CRITICAL: Failed to resolve hostname [snitswducspg1b] to IP address (gethostbyname). 7/17/12 15:43:54.961  6104  CTIOSSoftphone  Thd(5320)  Attempting to resolve hostname [snitswducspg1b] to IP address (gethostbyname).
brian1mcc Wed, 07/18/2012 - 01:03
  • Silver, 250 points or more
It looks like your client can't resolve the hostname snitswducspg1b. Can you ping this hostname?
If not, try adding it to your clients hosts file.
Brian
david.macias Wed, 07/18/2012 - 05:26
  • Blue, 1500 points or more
Brian is correct, your agent pc can't resolve the hostname snitswducspg1b.  You have a few choices.  Rerun ctios setup and remove hostnames and use nothing but IPs.  Put a host entry in your local windows hosts file.  Or change your network configuration to attach the fully qualified domain name of that server.
david
