LMS4 Syslog automated action anomaly
Jul 17th, 2012
LMS 4.2.1 on W2K8 R2
I just want to send an email for any sev 1 or 2 syslog messages received.  I set up an automated action that looks like this:
Automated Action Summary
Name: Critical Events Email
Devices: *
State: Enabled
Parameters: [email protected], SUB=LMS4 Syslog AA, TEXT=
Action Type: Email
Messages: *-*-1-*:* *-*-2-*:*
Yet I seem to be getting emails triggered by messages from ASA devices that are not severity 1 or 2, like:
%ASA-session-4-106023
%ASA-auth-3-109023
%ASA-auth-6-109001
Am I doing something wrong, or is there some sort of bug I am hitting?  I can't believe that I am the first person to try this.
-Jeff
Martin Ermel Fri, 08/10/2012 - 09:01
  • Blue, 1500 points or more
I do not know what exactly you have done so far but in your situation I would enable the following debugs:
open that file in a text editor
NMSROOT\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data\Collector.properties
and change the debug level from Info to Debug:
    DEBUG_LEVEL=DEBUG
also enable SyslogAnalyzer debugging here:
Admin > System > Debug Settings > Config and Image Management Debugging Settings
    Set Application Logging Levels >> SyslogAnalyzer (scroll down)
        set Syslog Analyzer and Syslog Analyzer User Interface from INFO to DEBUG
in a DOS box check the status of the following processes (the should be started) and restart them:
    pdshow SyslogAnalyzer SyslogCollector
    pdterm SyslogAnalyzer SyslogCollector
    pdexec SyslogAnalyzer SyslogCollector
When the issue happens again check the following log files and post them on the forum:
    NMSROOT\log\SyslogCollector.log
    NMSROOT\log\AnalyzerDebug.log
jedavis Fri, 08/10/2012 - 09:05
I have a case open with TAC and I have supplied them with the debug logs.  Apparently I am not the only one to report this.  The case has been escalated and I am waiting for a solution.  I expect that a patch will be required.
Related Content
