Warning message
Please help regarding these outputs....
Jul 18th, 2012
Hi Frnd,
Pls help me regarding below output --
volkswagen_aurangabad2_in_mpls#sh int s0/0/1:0
Serial0/0/1:0 is up, line protocol is up
  Hardware is GT96K Serial
  Description: * Connected to PE4-PNQ-AP Serial4/0/18:0 *
  MTU 1500 bytes, BW 1984 Kbit, DLY 20000 usec,
  Encapsulation FRAME-RELAY IETF, loopback not set
  Bundle Link of bundle MFR997
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1w0d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 30
  Queueing strategy: fifo
  Output queue: 0/5 (size/max)
  5 minute input rate 0 bits/sec, 1 packets/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
    4674537 packets input, 2589523774 bytes, 0 no buffer
    Received 0 broadcasts, 9 runts, 0 giants, 0 throttles
    865 input errors, 865 CRC, 144 frame, 4 overrun, 0 ignored, 135 abort
    3926773 packets output, 1304942401 bytes, 0 underruns
    4 carrier transitions          <<<<<<<<<<<<<<<<<<<<<<<<wats the mean of this or carier transition
  Timeslot(s) Used:1-31, SCC: 1, Transmitter delay is 0 flags
and also check below logs for controllers--
Jul 14 05:44:46.659 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface MFR997, changed state to up
Jul 14 05:44:47.907 CEST: %BGP-5-ADJCHANGE: neighbor 212.21.217.140 Up
Jul 14 05:44:54.371 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel14, changed state to up
Jul 14 05:44:54.375 CEST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
Jul 14 05:44:56.979 CEST: %BGP-5-ADJCHANGE: neighbor 62.134.22.34 Up
Jul 14 07:19:05.740 CEST: %HSRP-6-STATECHANGE: GigabitEthernet0/0 Grp 0 state Active -> Speak
Jul 14 11:58:15.472 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected) <<<<<<<<<
Jul 14 11:58:16.472 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
Jul 14 11:58:56.221 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to down (LOF detected)  <<<<<<<<<<
Jul 14 11:58:56.473 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (AIS detected)<<<<<<<<
Jul 14 11:58:58.221 CEST: %LINK-3-UPDOWN: Interface Serial0/0/1:0, changed state to down
Jul 14 11:58:58.473 CEST: %LINK-3-UPDOWN: Interface Serial0/0/0:0, changed state to down
Jul 14 11:58:58.477 CEST: %LINK-3-UPDOWN: Interface MFR997, changed state to down
Jul 14 11:58:59.221 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/1:0, changed state to down
Jul 14 11:58:59.473 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:0, changed state to down
Jul 14 11:58:59.477 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface MFR997, changed state to down
Jul 14 11:59:04.222 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to up
Jul 14 11:59:04.474 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
Jul 14 11:59:06.222 CEST: %LINK-3-UPDOWN: Interface Serial0/0/1:0, changed state to up
Jul 14 11:59:06.474 CEST: %LINK-3-UPDOWN: Interface Serial0/0/0:0, changed state to up
Jul 14 11:59:15.170 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel14, changed state to down
Jul 14 11:59:15.174 CEST: %BGP-5-ADJCHANGE: neighbor 62.134.22.34 Down Interface flap
Jul 14 11:59:20.234 CEST: %LINK-3-UPDOWN: Interface MFR997, changed state to up
Jul 14 11:59:21.226 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/1:0, changed state to up
Jul 14 11:59:21.234 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface MFR997, changed state to up
Jul 14 11:59:21.466 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:0, changed state to up
Jul 14 11:59:45.171 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel14, changed state to up
Jul 14 11:59:47.215 CEST: %BGP-5-ADJCHANGE: neighbor 62.134.22.34 Up
Jul 14 14:14:46.502 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (LOF detected)<<<<<<<<<<
Jul 14 14:14:47.502 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
Jul 15 17:14:38.954 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel14, changed state to down
Jul 15 17:14:38.958 CEST: %BGP-5-ADJCHANGE: neighbor 62.134.22.34 Down Interface flap
Jul 15 17:15:08.955 CEST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Jul 15 17:25:48.977 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel14, changed state to up
Jul 15 17:25:48.981 CEST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
Jul 15 17:26:09.498 CEST: %BGP-5-ADJCHANGE: neighbor 62.134.22.34 Up
Jul 15 17:38:09.002 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel14, changed state to down
Jul 15 17:38:09.006 CEST: %BGP-5-ADJCHANGE: neighbor 62.134.22.34 Down Interface flap
Jul 15 17:38:29.003 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel14, changed state to up
Jul 15 17:39:02.476 CEST: %BGP-5-ADJCHANGE: neighbor 62.134.22.34 Up
Jul 16 19:47:10.653 CEST: %SYS-5-CONFIG_I: Configured from console by voyence on vty0 (195.182.112.252)
Jul 17 11:24:15.308 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)  <<<<<<<<<<
Jul 17 11:24:16.308 CEST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
And also check the below controller status....
volkswagen_aurangabad2_in_mpls#sh controller e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20040802, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line Independent.  <<<<<<<<<<<<samething here....
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (255 seconds elapsed):
    0 Line Code Violations, 0 Path Code Violations
    0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
    0 Line Code Violations, 6 Path Code Violations,
    0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 0/0/1 is up.
  No alarms detected.
  Framing is CRC4, Line Code is HDB3, Clock Source is Line Independent.  <<<<<<<<<<<<clock source is set to line independent
  Data in current interval (256 seconds elapsed):
    0 Line Code Violations, 16 Path Code Violations,
    0 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
    0 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
vmiller Mon, 07/30/2012 - 10:02
  • Gold, 750 points or more
You have layer 1 issues on E1 0/0/1. looks like some los of framing
Time to get the carrier involved.
darren.g Mon, 07/30/2012 - 16:01
  • Silver, 250 points or more
You are receiving link errors from the communications service - AIS is Alarm Indication Signal, LOF is Loss Of Framing and RAI is Remote Alarm Indication - in short, your link is having issues, and you need to talk to your telco/carrier to get it investigated.
Cheers.
