Warning message
Web Service Execute Activity
Jul 18th, 2012
  • Cisco Employee,
Using the Web Service Execute activity, I get the following error when I try to load the methods using wsdl https://srm-app-003:9007/srm.wsdl
When I try to run the workflow, I get the following error:
    Error attempting to discover web service
     There was an error downloading 'https://srm-app-003:9007/srm.wsdl'.
     The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
     The remote certificate is invalid according to the validation procedure.
To try to fix the issue, I went to the Target tab, then Web Target properties and checked "Ignore Certificate Errors" checkbox under Connection Tab.
Then I tried running it again and this time I get the following error:
     Exception has been thrown by the target of an invocation.
     Unable to generate a temporary class (result=1).
     error CS0001: Internal compiler error (0xc00000fd)
     error CS0003: Out of memory
Have you seen this error before and how do I can I circumvent this issue?
Thank you in advance for your help.
Mary Jane Cofino
Christopher Roberts Wed, 07/18/2012 - 13:36
  • Cisco Employee,
Hi Mary Jane,
What version of CPO are you using? I was able to load this WSDL up in 2.3 and see the methods. It took a few moments to load fully as it appears to be a large WSDL but it loaded.
How much memory is on your VM/server you are using with CPO?
If you want more in-depth help, please open a TAC case and someone from my team can help you.
thanks,
Shaun Roberts
CPO/CIAC Support Team Lead
[email protected]
