asa 8.6 static command
sorry i am lost
We are trying to get our dhcp server (public.x.x.x) on vlan 1 with 10.25.0.1 scope to service the asa on vlan 3.
We input the following:
dhcprelay server public.x.x.x outside
dhcprelay enable inside
dhcprelay setroute inside
I thought the next step was to create a static from the inside to outside for the IP address of the inside interface. I thought this would allow the inside interface to relay the dhcp broadcast to your dhcp server with its private address. The command on pre8.3 was something like:
static (inside,outside) 10.25.0.1 10.25.0.1 netmask 255.255.240.0
Karsten Iwen Fri, 07/20/2012 - 07:38
I'm pretty sure you don't need NAT for the dhcprelay to work. NAT is for traffic passing through the ASA, but with dhcprelay the ASA receives the packets and generates a new request based on the received packet. There shouldn't be any NAT be involved.
Thanks Ramraj,
I have the options set as the gui suggests my external dhcp server is at 165.234.128.9 and i have a scope setup on it for 10.25.0.0:
dhcprelay server 165.234.128.9 outside
dhcprelay server 10.25.0.1 outside
Within that link you mention above i am having trouble with the ip route statement:
!--- This command creates a static route in order to
!--- route the reply packets to the DHCP relay interface.
ip route 10.1.1.0 255.255.255.0 10.2.1.1
the command ip route is not available apparantly on ver 8.6, below is what happens:
ciscoasa(config)# ip route
ERROR: % Invalid input detected at '^' marker.
ciscoasa(config)# ip ?
configure mode commands/options:
  audit   Configure the Intrusion Detection System
  local   Define a local pool of IP addresses
  verify  Configure Unicast Reverse Path Filtering on an interface
Karsten Iwen Mon, 07/23/2012 - 10:54
the "ip route" is no command that you have to enter on the ASA. The config you posted on
19.07.2012, 23:34 is exactly what you need to enable a DHCP relay. Nothing more is needed.
If it still doesn't work, the reason will probably be somewhere else. You could try to capture the packets to see how far they get.
Karsten Iwen Mon, 07/23/2012 - 11:18
And just to make sure we're talking about the same scenario:
Your clients are directly connected to the inside interface on the ASA without a L3-instance between them?
didn't see your earlier post.  Was on tech support with ciso and they did setup a packet trace.  They found the packets are getting to the dhcp server but when the server replies they are being discarded. Cisco thought it was configuration of the external dhcp server but we have not found a solution that works yet.
Karsten Iwen Mon, 07/23/2012 - 11:45
what is the log message when the packets are discarded?
Karsten Iwen Mon, 07/23/2012 - 14:10
In the asp.pcap, there are only DHCP-offers with client-addresses in the 165.234.128.0-network. Are these captures really related to the problem? The DHCP-server should offer an IP in the 10.25.0.0/20 network.
That is a question we have been asking ourselves too.
When filtering asp.pcap with ip.addr==165.234.128.9 on row No. 103 we find the mac address of the client we are trying to get an ip address on (64:31:50:95:43:2c).
We have 2 scopes on our dhcp server.  How does a client on the inside of the ASA know which scope to pick from and for the matter how does one on the outside know which scope to pick from?
Karsten Iwen Mon, 07/23/2012 - 14:44
The relay-agent includes his own ip address from that interface that received the DHCP-request. The DHCP-server then searches for a matching scope. You have a DHCP-Pool starting at 10.25.0.0?
Karsten Iwen Mon, 07/23/2012 - 23:51
To get more information where the problem is, I would set up an additional DHCP-Server (an IOS-router or -switch) with the same scope and add this server to the ASA ("dhcprelay server 165.234.128.X outside"). When there are two DHCP-servers specified, both should get the request and we can see if the second server answers in a way that the ASA accepts.
Ramraj Sivagnan... Wed, 07/25/2012 - 02:32
Hi Bro
Your DHCPRELAY configuration is wrong. You are currently having this, which is wrong;
dhcprelay server 10.25.0.1 outside <--- This is your DHCP Scope not your DHCP Server
Instead, you should have this;
P/S: If you think this comment is useful, please do rate them nicely :-)
Thanks for your continued attention.
The configuration you suggest was our original configuration:
However we are unable to get an ip address on the client.
We did setup another dhcp server and put it on the inside, changed the config  to no dhcprelay.... .  And the client was able to get an ip and had internet access.
So we have been successful in using the ASA's dhcp server, also successful in using an stand-alone dhcp server located on the inside of the ASA (with the ASA's dhcp server disabled).
But when we try to get the dhcp server on the outside as you have stated in the above commands we have not had success.
Here is the running-config:
ciscoasa#
ciscoasa# show running-config
: Saved
ASA Version 8.6(1)
hostname ciscoasa
enable password ibqCJZNHhOXYLjS3 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 165.234.128.203 255.255.248.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.25.0.1 255.255.240.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa861-smp-k8.bin
ftp mode passive
clock timezone MST -7
clock summer-time MDT recurring
object-group network wireless
network-object 10.25.0.0 255.255.255.0
access-list outbound extended permit ip any any
access-list outbound extended permit icmp any any
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
asdm image disk0:/asdm-66114.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) after-auto source dynamic any interface
access-group outbound in interface outside
access-group outbound in interface inside
access-group outbound out interface inside
route outside 0.0.0.0 0.0.0.0 165.234.128.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
csd image disk0:/csd_3.5.2008-k9.pkg
anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 1
anyconnect image disk0:/anyconnect-linux-2.5.2014-k9.pkg 2
anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 3
username admin password RSRFwwciBS8x/1/M encrypted
username dsu password RSRFwwciBS8x/1/M encrypted privilege 15
username pix password n5jkqOP4vOe/4pzS encrypted
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http
https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email
[email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 10
  subscribe-to-alert-group configuration periodic monthly 10
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:49ca48250c21eec0abd300facb57c935
: end
ciscoasa#
Ramraj Sivagnan... Wed, 07/25/2012 - 09:49
Hi Bro
Please do this, and let me know the outcome;
  no ip address 10.25.0.1 255.255.240.0
  ip address 10.25.0.1 255.255.255.0
no nat (inside,outside) after-auto source dynamic any interface
no nat-control
no access-group outbound out interface inside
no dhcpd address 192.168.1.2-192.168.1.254 management
route outside 165.234.128.9 255.255.255.255 165.234.128.2 // Try with this, and without this //
Did as above with exception of , no nat-control.
following was the output when i tried:
ciscoasa(config)# no nat
ERROR: % Incomplete command
ciscoasa(config)# nat ?
  (               Open parenthesis for (,)
                  pair where is the Internal or prenat
                  interface and is the External or postnat
                  interface
  <1-2147483647>  Position of NAT rule within before auto section
  after-auto      Insert NAT rule after auto section
  source          Source NAT parameters
Karsten Iwen Mon, 07/30/2012 - 07:17
Have you tried a different DHCP-Server on the outside to see what happens?
Here is the output of debug chcprelay packet:
ciscoasa# debug dhcprelay packet
debug dhcprelay packet enabled at level 1
ciscoasa# DHCPRA: relay binding found for client 6431.5095.432c.
DHCPD: setting giaddr to 10.25.0.1.
dhcpd_forward_request: request from 6431.5095.432c forwarded to 165.234.128.9.
Ramraj Sivagnan... Mon, 08/06/2012 - 21:11
Hi Bro
I'm so sorry for the late reply, as I've been away and just got back to work today. I don't see anything wrong with your DHCP debug outputs. Can you paste your config here, so that I could simulate your actual config in my FW?
tapfuma72 Wed, 04/09/2014 - 19:04
Can anyone tell me if this conversion is correct i am having major issues trying to convert my original commands with the new ones
Old Configuration
static (inside,outside) udp interface 450000 10.0.0.1 4500 netmask 255.255.255.255
static (inside,outside) udp interface isakmp 10.0.0.1 isakmp netmask 255.255.255.255
static (inside,outside) tcp interface 22222 10.0.0.1 ssh netmask 255.255.255.255
New Migration
1)
 object network object udp-450000
 host 10.0.0.1
 nat (inside,outside) static 69.255.255.41
2)
 object network object udp-isakmp
  host 10.0.0.1
  nat (inside,outside) static 69.255.255.41 service udp 450000
3)
 object network object tcp-22222
  host 10.0.0.1
  nat (inside,outside) static 69.255.255.41 service tcp 22222
