vpn-filter permit any any blocks all AnyConnect traffic
Jul 19th, 2012
I am using AnyConnect with Radius on a asa5510.  Radius defines which group-policy should apply to each AnyConnect client.
I'd like to use a different vpn-filter for each group-policy group.  With no vpn-filter defined, AnyConnect clients can communicate with inside networks and outside (via nat).  However, defining any vpn-filter asa group-policy attribute seems to drop all connectivity for AnyConnect client tunnels in that group.  Even something as simple as:
access-list FILTER1 extended permit ip any any
group-policy GROUP1 attributes
vpn-filter value FILTER1
...seems to drop all traffic.  Deleting the single vpn-filter line restores connectivity.
I'm unsure how to packet-trace traffic entering via AnyConnect to see where the problem lies.
-Bradley
Jennifer Halim Fri, 07/20/2012 - 00:51
  • Cisco Employee,
Did you reconnect the AnyConnect vpn after the changes? or you stay connected to the AnyConnect after the changes?
Bradley Urberg ... Fri, 07/20/2012 - 09:13
Thanks, Jennifer:  yes, I am bringing-up a new AnyConnect session after making the changes, to test.  Is there a way to do a "packet trace" which shows packet flow through a vpn-filter?
Jennifer Halim Sun, 07/22/2012 - 03:49
  • Cisco Employee,
what version of ASA and ANyConnect are you running?
Bradley Urberg ... Sun, 07/22/2012 - 18:48
Hardware:   ASA5510-K8, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
This platform has an ASA 5510 Security Plus license.
System image file is "disk0:/asa825-k8.bin"
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
My AnyConnect client is version 2.5.0217
Related Content
