Warning message
Interface shut/no shut using ip sla with EEM applet
Answered Question
Jul 20th, 2012
I have to come up with a script to 'shut' a particular interface on a router (3945E running IOS 15.0) when a link goes down and also to 'no shut' it after the link comes back up. This is what I have so far.
track 1 ip sla 10 reachability
delay down 10 up 10
ip sla 10
icmp-echo 192.168.0.1 source-interface GigabitEthernet 0/1
frequency 30
ip sla schedule 10 life forever start-time now
event manager applet Link-Down
event track 1 state down
action 1.0 syslog msg "Reply timed out; Link is down"
action 1.1 cli command "enable"
action 1.2 cli command "conf t"
action 1.3 cli command "interface g0/0"
action 1.4 cli command "shut"
action 1.5 cli command "end"
action 1.6 syslog msg "Interface GigabitEthernet 0/1 shutdown"
event manager applet Link-Up
event track 1 state up
action 1.0 syslog msg "Ping received; Link is up"
action 1.4 cli command "no shut"
action 1.6 syslog msg "Interface GigabitEthernet 0/1 up"
I have to go to a remote site and get this working within a short maintenance window but unfortunately I have no way of testing it out and I dont want to go in blind. So, if someone could verify that the script will work with my IOS version, that'll be great.
Correct Answer by Joe Clarke about 5 years 4 weeks ago
This will work, but your syslog message seems to indicate that the wrong interface is being shutdown.  You may also need "event manager session cli username USER" if your router uses AAA command authorization.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 07/20/2012 - 11:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
KUNAL HANS Fri, 07/20/2012 - 13:10
Woops, yeah should be g0/0 in the syslog msg also. Thx Joseph!
