Cisco ASR 9010 Copper port problem
Jul 21st, 2012
Recently we have purchased Cisco ASR 9010 router. We have setup a 1Gbps copper based SFP module in the line card. It detect the module and I have found this by using show controller. But when I coonect a RJ-45 cable between thre router and my laptop, port do not up, even I connect the cable to a cisco switch that time also it is not working. Is there any command to up this port!
Please help.
Shuvo
Overall Rating: 5 (2 ratings)
Leo Laohoo Sun, 07/22/2012 - 00:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Your laptop has a triple-speed (10/100/1000BaseTx) NIC card?
nmarques.zapp Sat, 08/04/2012 - 15:22
try enabling autonegociation with:
no duplex
no speed
on the switch side try:
duplex full
if the SPF is ok it should come up.
jstuxuhu0816 Tue, 08/07/2012 - 08:10
Do you need to use the media-type command?
charlhug Tue, 08/07/2012 - 10:13
  • Cisco Employee,
You likely need "negotiation auto" configured under this port, as many devices have autonegotiation enabled by default but the ASR9000 does not. The "media-type" command is not present on the ASR9000 as it's used to switch between SFPs and fixed copper ports - not for copper SFPs.
jstuxuhu0816 Tue, 08/07/2012 - 19:12
For the "Negotiation auto", do you mean for 1000M interface, since the 10G interface is alwasy force-up.
Michalis Milaitis Wed, 08/08/2012 - 00:43
Try to configure this command under the interface :
"transceiver permit pid all"
mostakimulhuq Wed, 08/08/2012 - 02:58
Thank Michalis.
I have applied your command and it is working.
Thanks very much for your co-operation.
Shuvo
