SMARTNET
Answered Question
Jul 22nd, 2012
What is the difference of getting CON-SNT-SMS-1 instead of CON-SNT-2960S4FS and CON-SNT-2964STL?
Correct Answer by nkarthikeyan about 4 years 11 months ago
Hi John,
As per my knowledge CON-SNT-SMS-1 is for the SMS tool. I hope your purchased 2900 switch. So you can go with that. Even if you go through the link. It show manufacturing part as SMS in the second link. So always you have to choose your right model for your contract.
http://www.costcentral.com/proddetail/Cisco_SMARTnet_Extended_service_agreement/CONSNT2960S4FS/11114490/
http://www.costcentral.com/proddetail/Cisco_SMARTnet_Extended_service_agreement/CONSNTSMS1/612827/
Please do rate if the given information helps.
By
Karthik
Overall Rating: 5 (1 ratings)
nkarthikeyan Sun, 07/22/2012 - 20:06
  • Gold, 750 points or more
Hi John,
I understand your query. CON-SNT-SMS-1 is the smartnet code for the SMS tool i guess which is intergrated with the Cisco Works if am not wrong. I guess you have confused with the price variations..
CON-SNT-2960S4FS and CON-SNT-2964STL is the smartnet code for the specific models which you have purchased.
I feel you have purchased 2960 and 2964 which requires CON-SNT-2960S4FS and CON-SNT-2964STL. If you have purchased the SMS tool then CON-SNT-SMS-1 is required.
By
Karthik
john.dejesus Sun, 07/22/2012 - 20:19
Yes I am confused. :-) So If I am going to get a smarnet for those switches it should be CON-SNT-2960S4FS and CON-SNT-2964STL. The vendor told me that CON-SNT-SMS-1 will cover those two. Which is which?
Correct Answer
nkarthikeyan Sun, 07/22/2012 - 20:38
Hi John,
By
Karthik
Related Content
