Warning message
Analyze Firewall connections w.r.t Orion Network analyzer
Jul 23rd, 2012
Dear All,
I need to consider limiting my Firewall connections from outside network.
On a average i am receiving 4000 connections / second (witnessed almost a month on daily basis)
hostname# sh conn count
3559 in use, 6657 most used
So what will be the preferred value to be configured by the MQC in  firewall.
hostname(config)# class-map  CONNS
hostname(config-cmap)# match  any
hostname(config-cmap)#  policy-map CONNS
hostname(config-pmap)# class  CONNS
hostname(config-pmap-c)# set  connection conn-max 4000 embryonic-conn-max 12000
hostname(config-pmap-c)# set  connection timeout tcp 2:0:0 embryonic 0:40:0 half-closed 0:20:0  dcd
hostname(config-pmap-c)# service-policy CONNS interface outside
Also, i have established Orion Solarwinds Network performance monitor (version 10.3)  to verify the number of connections.
My query's are follows..
++ Can i restrict the above values as defined in MQC.
++ Can anyone help me how to locate the similar connections in Orion monitor.
Best Regards / Vimal.
Overall Rating: 5 (1 ratings)
Amjad Abdullah Mon, 07/23/2012 - 02:36
  • Red, 2250 points or more
Hi Vimal,
I think you better move the post to security forums. This sub-forum is about security and management under wireless.
I think you meant to put the post in security forums not in wireless forums.
Amjad
vimal_raj Mon, 07/23/2012 - 02:49
Thanks for the info Amjad.
I have moved to the respective forum: Security ---> Security Management
Regards/ Vimal.
