cisco catalyst 2960 IOS ver12.2(53)se2
Answered Question
Jul 23rd, 2012
Pls help
have
cisco catalyst 2960 IOS ver12.2(53)se2 when power on the power LED does not come up and on this is what shown on hpertermianal
what need to be done for this switch pls?
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: b4:d9:8d:27:4c:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 536 files, 19 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 3671040
flashfs[0]: Bytes available: 28843008
flashfs[0]: flashfs fsck took 10 seconds.
...done Initializing Flash.
done.
Loading ""...: no such device
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
switch:
switch:
Thx
joseph
Correct Answer by Peter Paluch about 4 years 11 months ago
Hello Joseph,
Hmmm... This seems as if the IOS image was deleted... Can you please enter the following command and post the results?
dir flash:/c2960-lanbasek9-mz.122-53.SE2
Thank you!
Best regards,
Peter
Overall Rating: 5 (1 ratings)
Alessio Andreoli Mon, 07/23/2012 - 04:54
  • Silver, 250 points or more
get in the ROM and re-initialize the flash according the machine you have.
Maybe you will lose the config but it should fix the issue.
Alessio
Peter Paluch Mon, 07/23/2012 - 04:56
  • Cisco Employee,
Joseph,
Please capture and attach the output of the two following commands entered in the bootloader mode:
set
dir flash:
Thank you!
Best regards,
Peter
malai.joseph Mon, 07/23/2012 - 05:06
switch:
switch: set
CLEI_CODE_NUMBER=COMMK00ARF
MAC_ADDR=B4:D9:8D:27:4C:00
MODEL_NUM=WS-C2960-24TT-L
MODEL_REVISION_NUM=J0
MOTHERBOARD_ASSEMBLY_NUM=73-12600-04
MOTHERBOARD_REVISION_NUM=B0
MOTHERBOARD_SERIAL_NUM=FOC14480GCB
POWER_SUPPLY_PART_NUM=341-0097-03
POWER_SUPPLY_SERIAL_NUM=DCA14458PDJ
SDM_TEMPLATE_ID=0
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FOC1415X4WV
TAN_NUM=800-32797-01
TAN_REVISION_NUMBER=D0
VERSION_ID=V02
switch: dir flash
unknown cmd:dir
switch:
Peter Paluch Mon, 07/23/2012 - 05:10
  • Cisco Employee,
Hello Joseph,
It is possible that you have used a special key, such as an arrow key, TAB or similar, when you entered the dir flash: command. That is the reason why the command was not accepted - these keys are not supported in the bootloader mode and actually cause the following command to be rejected as unknown.
Press Enter a few times in an empty command line to make sure that no remaining (invisible) characters have been left unprocessed in the command line buffer. Then enter the following command once again:
dir flash:
Remember to write the colon after the "flash" keyword. Do not use TAB, arrows or any other special keys. If you happen to make a typo, use only the Backspace key to erase the line and correct the typo.
Waiting for your reply.
Best regards,
Peter
malai.joseph Mon, 07/23/2012 - 05:15
switch:dir flash:
Unknown cmd:dir
switch: dir flash:
Directory of flash:/
    2  -rwx  1048                     multiple-fs
    3  drwx  192                      c2960-lanbasek9-mz.122-53.SE2
28843008 bytes available (3671040 bytes used)
switch:
Peter Paluch Mon, 07/23/2012 - 05:20
  • Cisco Employee,
Hello Joseph,
Alright. Try entering the following commands very carefully without any typos (as you can see above, using the special keys inevitably leads to trouble):
set BOOT flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE2.bin
boot
Ideally, try to copy these both commands onto clipboard and then paste them into Hyperterminal by right-clicking anywhere in the Hyperterminal window and choosing the "Paste to Host" function (avoid using Ctrl-V - that won't work).
Post the results back here please.
Best regards,
Peter
malai.joseph Mon, 07/23/2012 - 05:31
switch: set BOOT flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.
SE2.bin
switch: boot
Loading "flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE2.bin"
...flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE2.bin: short
read: bad mzip file
Error loading "flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE
2.bin"
switch:
Correct Answer
Peter Paluch Mon, 07/23/2012 - 05:47
  • Cisco Employee,
Hello Joseph,
Thank you!
Best regards,
Peter
malai.joseph Tue, 07/24/2012 - 00:15
Thx Peter for your nice assistance but supplier took it while i was troubleshooting with ur assistance,i appreciate it
thx
j
Peter Paluch Tue, 07/24/2012 - 02:21
  • Cisco Employee,
Hello Joseph,
Oh I see. We were so close to solving the mystery
Nevertheless, I would like to thank you. You  have been very responsive to my requests, and it was a pleasure assisting you.
Best regards,
Peter
beshoo507 Mon, 08/03/2015 - 13:40
switch: set
BOARD_CONFIG_REV=0
BOOT=flash:/c2960-lanbasek9-122-53.SE2/c2960-lanbasek-mz.122-53.SE.bin boot
CLEI_CODE_NUMBER=COMC400ARB
MAC_ADDR=D0:C7:89:77:78:00
MODEL_NUM=WS-C2960-48PST-L
MOTHERBOARD_ASSEMBLY_NUM=73-12618-03
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FCQ17190GWJ
POWER_SUPPLY_PART_NUM=341-0266-03
POWER_SUPPLY_SERIAL_NUM=LIT17161FJY
SDM_TEMPLATE_ID=0
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FCQ1719Y5C3
TAN_NUM=800-32814-02
TAN_REVISION_NUMBER=A0
VERSION_ID=V05
switch: dir flash
unable to stat flash/: no such device
Related Content
