FXO : Outgoing calls getting fast busy
georgemaier
I must be doing something wrong, but can't figure out what.
3 POTS lines connected to 3 FXO ports.  Incoming calls seem to work as planned.
Outgoing calls are a different story: when some makes the first outgoing call on an idle system then it rings thu OK , but when a second extension tries to also call out it will get a busy signal most of the time (4 out of 5 times).
The interesting thing is that if the second extension hits "redial" immediately, the calls go though! Any idea why?
Thank you!
Config:
version 12.4
hostname cisco
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 **************
enable password **************
no aaa new-model
clock timezone CST -6
clock summer-time CDT recurring
dot11 syslog
no ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool VOICE
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 4.2.2.2
   option 150 ip 10.10.10.1
ip cef
no ip domain lookup
ip name-server 208.67.222.222
ip name-server 208.67.220.220
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/2/0
  fallback-dn 203
trunk group 1
hunt-scheme round-robin
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
sip
  registrar server expires max 36000 min 600
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 12
max-pool 12
authenticate realm cisco.com
time-format 24
date-format D/M/Y
create profile sync 0042103825165098
voice register dn  1
number 222
name Scale Speaker
no-reg
voice register pool  1
id mac 0020.F750.0B3A
number 1 dn 1
username 222 password ext222
codec g711ulaw
no vad
voice translation-rule 4
rule 1 /^9\(1..........\)/ /\1/
rule 2 /^9/ //
voice translation-rule 5
rule 1 /^8\(1..........\)/ /\1/
rule 2 /^8/ //
voice translation-profile POTS
translate called 5
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 192.168.1.210 255.255.255.0
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
ip helper-address 192.168.1.210
interface Service-Engine0/1
ip unnumbered FastEthernet0/0.10
service-module ip address 10.10.10.2 255.255.255.0
service-module ip default-gateway 10.10.10.1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip route 10.10.10.2 255.255.255.255 Service-Engine0/1
ip http server
no ip http secure-server
ip http path flash:gui
tftp-server flash:apps11.8-4-1-23.sbn
tftp-server flash:apps31.8-4-1-23.sbn
tftp-server flash:apps37sccp.1-2-1-0.bin
tftp-server flash:apps41.8-4-1-23.sbn
tftp-server flash:apps42.8-4-1-23.sbn
tftp-server flash:apps45.8-4-1-23.sbn
tftp-server flash:apps70.8-4-1-23.sbn
tftp-server flash:apps75.8-4-1-23.sbn
tftp-server flash:cnu11.8-4-1-23.sbn
tftp-server flash:cnu31.8-4-1-23.sbn
tftp-server flash:cnu41.8-4-1-23.sbn
tftp-server flash:cnu42.8-4-1-23.sbn
tftp-server flash:cnu45.8-4-1-23.sbn
tftp-server flash:cnu70.8-4-1-23.sbn
tftp-server flash:cnu75.8-4-1-23.sbn
tftp-server flash:CP7921G-1.2.1.LOADS
tftp-server flash:cvm11sccp.8-4-1-23.sbn
tftp-server flash:cvm31sccp.8-4-1-23.sbn
tftp-server flash:cvm41sccp.8-4-1-23.sbn
tftp-server flash:cvm42sccp.8-4-1-23.sbn
tftp-server flash:cvm45sccp.8-4-1-23.sbn
tftp-server flash:cvm70sccp.8-4-1-23.sbn
tftp-server flash:cvm75sccp.8-4-1-23.sbn
tftp-server flash:dsp11.8-4-1-23.sbn
tftp-server flash:dsp31.8-4-1-23.sbn
tftp-server flash:dsp41.8-4-1-23.sbn
tftp-server flash:dsp42.8-4-1-23.sbn
tftp-server flash:dsp45.8-4-1-23.sbn
tftp-server flash:dsp70.8-4-1-23.sbn
tftp-server flash:dsp75.8-4-1-23.sbn
tftp-server flash:jar11sccp.8-4-1-23.sbn
tftp-server flash:jar31sccp.8-4-1-23.sbn
tftp-server flash:jar41sccp.8-4-1-23.sbn
tftp-server flash:jar42sccp.8-4-1-23.sbn
tftp-server flash:jar45sccp.8-4-1-23.sbn
tftp-server flash:jar70sccp.8-4-1-23.sbn
tftp-server flash:jar75sccp.8-4-1-23.sbn
tftp-server flash:SCCP11.8-4-2S.loads
tftp-server flash:SCCP31.8-4-2S.loads
tftp-server flash:SCCP41.8-4-2S.loads
tftp-server flash:SCCP42.8-4-2S.loads
tftp-server flash:SCCP45.8-4-2S.loads
tftp-server flash:SCCP70.8-4-2S.loads
tftp-server flash:SCCP75.8-4-2S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:term31.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:term42.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:ringtones/Analog1.raw
tftp-server flash:ringtones/Analog2.raw
tftp-server flash:ringtones/AreYouThere.raw
tftp-server flash:ringtones/AreYouThereF.raw
tftp-server flash:ringtones/Bass.raw
tftp-server flash:ringtones/CallBack.raw
tftp-server flash:ringtones/Chime.raw
tftp-server flash:ringtones/Classic1.raw
tftp-server flash:ringtones/Classic2.raw
tftp-server flash:ringtones/ClockShop.raw
tftp-server flash:ringtones/DistinctiveRingList.xml
tftp-server flash:ringtones/Drums1.raw
tftp-server flash:ringtones/Drums2.raw
tftp-server flash:ringtones/FilmScore.raw
tftp-server flash:ringtones/HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw
tftp-server flash:ringtones/Piano1.raw
tftp-server flash:ringtones/Piano2.raw
tftp-server flash:ringtones/Pop.raw
tftp-server flash:ringtones/Pulse1.raw
tftp-server flash:ringtones/Ring1.raw
tftp-server flash:ringtones/Ring2.raw
tftp-server flash:ringtones/Ring3.raw
tftp-server flash:ringtones/Ring4.raw
tftp-server flash:ringtones/Ring5.raw
tftp-server flash:ringtones/Ring6.raw
tftp-server flash:ringtones/Ring7.raw
tftp-server flash:ringtones/RingList.xml
tftp-server flash:ringtones/Sax1.raw
tftp-server flash:ringtones/Sax2.raw
tftp-server flash:Desktops/320x212x12/CRCLogo.png
tftp-server flash:Desktops/320x212x12/TN-CRCLogo.png
control-plane
voice-port 0/1/0
trunk-group 1
pre-dial-delay 0
no vad
timeouts wait-release 5
timing hookflash-out 250
connection plar opx 601
description FXO 630-555-1499
station-id number 6305551499
caller-id enable
voice-port 0/1/1
trunk-group 1
pre-dial-delay 0
no vad
description FXO 630-555-1500
station-id number 6305551500
caller-id enable
voice-port 0/1/2
trunk-group 1
pre-dial-delay 0
no vad
description FXO 630-555-1502
station-id number 6305551502
caller-id enable
voice-port 0/1/3
voice-port 0/2/0
timeouts ringing infinity
caller-id enable
voice-port 0/2/1
sccp local FastEthernet0/0.10
sccp ccm 10.10.10.1 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
switchback method graceful
dial-peer voice 900 pots
trunkgroup 1
description prefix 8 uses POTS line
translation-profile outgoing POTS
destination-pattern 81[2-9].........
prefix ,
no sip-register
dial-peer voice 600 voip
description *** Voicemail Pilot ***
destination-pattern 600
session protocol sipv2
session target ipv4:10.10.10.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 10 pots
service stcapp
port 0/2/0
dial-peer voice 601 voip
description *** Auto Attendant ***
destination-pattern 601
codec g711ulaw
no vad
dial-peer voice 911 pots
trunkgroup 1
destination-pattern 911
prefix 911
no sip-register
dial-peer voice 9911 pots
trunkgroup 1
destination-pattern 9911
forward-digits 3
no sip-register
dial-peer voice 8911 pots
trunkgroup 1
destination-pattern 8911
forward-digits 3
no sip-register
dial-peer voice 602 voip
description *** AvT ***
destination-pattern 602
codec g711ulaw
no vad
sip-ua
telephony-service
authentication credential admin ********
max-ephones 30
max-dn 150
ip source-address 10.10.10.1 port 2000
url services http://10.10.10.2/voiceview/common/login.do
url authentication http://10.10.10.1/CCMCIP/authenticate.asp
load 7916-24 B016-1-0-2
load 7965 SCCP45.8-4-2S.loads
load 7975 SCCP75.8-4-2S.loads
time-zone 8
voicemail 600
max-conferences 4 gain -6
moh music-on-hold.au
web admin system name admin secret 5 **********
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 8
create cnf-files version-stamp 7960 Nov 30 2011 13:22:23
ephone-dn  11
number 6305551499
label Line1 630-555-1499
name ATT Line 1
ephone-dn  12
number 6305551500
label Line2 630-555-1500
name ATT Line 2
ephone-dn  13
number 6305551502
label Line3 630-555-1502
name ATT Line 3
ephone-dn  21  dual-line
call-waiting ring
number 204
label x204
allow watch
call-forward busy 600
call-forward noan 202 timeout 6
ephone-dn  22  dual-line
call-waiting ring
number 201
label x201
allow watch
call-forward all 600600
call-forward noan 600 timeout 10
ephone-dn  23  dual-line
call-waiting ring
number 205
label x205
allow watch
ephone-dn  24  dual-line
call-waiting ring
number 202
label x202
allow watch
call-forward noan 600 timeout 20
ephone-dn  25  dual-line
call-waiting ring
number 206
label x206
allow watch
ephone-dn  26
number 203
label x203 Collection Center
name Collection Center
allow watch
call-forward busy 205
call-forward noan 205 timeout 60
ephone-dn  27
number 208
label x208
ephone-dn  28
number 209
label x209
ephone-dn  30
number 8000...
mwi on
ephone-dn  31
number 8001...
mwi off
ephone-dn  50
number 500 no-reg primary
park-slot timeout 30 limit 10
ephone-dn  51
number 501 no-reg primary
ephone-dn  52
number 502
ephone  1
device-security-mode none
description aaa
mac-address E840.40A3.C8AB
username "aaa"
type 7965
button  1:21 2w22 3w23 4w24
button  5w25 6w26
ephone  2
description 7975
mac-address ECC8.82B1.88C2
username "bbb"
type 7975 addon 1 7916-24
button  1:22 2w24 3w26 4w21
button  5w23 6w25
ephone  3
description ccc
mac-address E840.40A3.C413
username "ccc"
type 7965
button  1:23 2w22 3w24 4w25
button  5w26 6:27
ephone  4
description ddd
mac-address E840.40A3.C982
username "ddd"
type 7965
button  1:24 2w22 3w23 4w21
button  5w26
ephone  5
description eee
mac-address E840.40A3.C7BD
username "eee"
type 7965
button  1:25 2w22 3w23 4w21
button  5w26 6:27
ephone  6
description fff
mac-address E840.40A3.C727
username "fff"
type 7965
button  1:28
ephone  9
description Analog Phone
mac-address 5632.2F50.2100
max-calls-per-button 2
type anl
button  1:26
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 130
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password ********
login
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
ntp master 1
ntp server 192.43.244.18
ntp server 129.6.15.28
end
11 Replies 11
paolo bevilacqua
Maybe the ports remained off-hook due to non-working supervisory disconnect, or perhaps there is no dialtone.
Check "show voice-port summary | inc fxo" and "debug vpm signal" with "term mon".
Chris Deren
Try adding trunk group preferences to the voice-ports, i.e.
voice-port 0/1/0
trunk-group 1 1
voice-port 0/1/1
trunk-group 1 2
etc
etc
Chris
Thank you for the replies.
Made the changes suggested by Chris but it made no difference.
We only have 3 pots lines plugged in to 3 of 4 ports on the FXO. Is it possible that CME is trying to use port 0/1/3 (which has nothing plugged into it)?
If I start out like this:
show voice port summary | inc fxo
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
And I place and outgoing call one of those lines go off hook as expected:
0/1/2           --  fxo-ls      up    up   idle     off-hook y
Then I tried to place a second call form a diferent extension/phone and get a busy (most of time).
Thanks.
George,
Can you try putting the pre dial delay back to default of 1 second
voice-port 0/1/0
no pre-dial-delay
voice-port 0/1/0
no pre-dial-delay
voice-port 0/1/2
no pre-dial-delay
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
You can solve it with "cable-detect" command if you are running IOS 15.1.1T or newer:
The FXO port is in the busyout state if the Digital Signal Processor (DSP) detects that no cable is connected between the analog Foreign eXchange Subscriber (FXS) and FXO ports. If you have configured the no cable-detect command and the analog FXO voice port is in busyout state because no cable is connected, the Cisco IOS software stops polling the cable connection. The analog FXO voice port remains in the busyout state until you use the shutdownand no shutdowncommands to switch the analog FXO voice port to the idle state. The cable-detect command supports loop start and Central Automatic Message Accounting (CAMA) signaling.
The cable-detect command can be configured on the following analog FXO voice interface cards (VICs):
  • VIC2-4FXO
  • EM-HDA-6FXO
  • EM-HDA-3FXS-4FXO
  • EM-HDA-4FXO
Examples
The following example shows how to enable cable polling on an FXO voice port:
Router> enable
Router# configure terminal
Router(config)# voice-port 1/2/3
Router(config-voiceport)# cable-detect
HTH,
Chris
"no pre-dial-delay" made no difference.
Cable detect won't work I am on 12.4
Here is the output from the debug ( I tried to place a call remotely I have no physical access to the phones at the moment):
cisco#term mon
cisco#debug vpm signal
Voice Port Module signaling debugging is enabled
cisco#csim start 816306775555
csim: called number = 816306775555, loop count = 1 ping count = 0
Jul 24 14:50:01.559: htsp_timer_stop3 htsp_setup_req
Jul 24 14:50:01.563: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]                                              fxols_onhook_setup
Jul 24 14:50:01.563: [0/1/2] set signal state = 0xC timestamp = 0
Jul 24 14:50:01.563: htsp_timer - 1300 msec
Jul 24 14:50:01.835: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG                                              _0110]fxols_disc_clear
Jul 24 14:50:01.835: htsp_timer_stop2
Jul 24 14:50:01.835: htsp_timer - 1300 msec
Jul 24 14:50:02.135: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG                                              _1100]fxols_power_denial_detected
Jul 24 14:50:02.135: htsp_timer2 - 1000 msec
Jul 24 14:50:02.135: htsp_timer_stop
Jul 24 14:50:02.343: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG                                              _0110]fxols_disc_clear
Jul 24 14:50:02.343: htsp_timer_stop2
Jul 24 14:50:02.343: htsp_timer - 1300 msec
Jul 24 14:50:03.643: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_HTSP_EV                                              ENT_TIMER]fxols_wait_dial_timer  htsp_dial
Jul 24 14:50:06.691: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_DONE, E_DSP_DIA                                              LING_DONE]fxols_wait_dial_done htsp_progress
Jul 24 14:50:06.691: htsp_timer - 350 msec
Jul 24 14:50:07.043: htsp_process_event: [0/1/2, FXOLS_WAIT_CUT_THRU, E_HTSP_EVE                                              NT_TIMER]fxols_handle_cut_thru
Jul 24 14:50:07.043: htsp_timer_stop .
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 1
cisco#
Jul 24 14:50:30.043: htsp_timer_stop3
Jul 24 14:50:30.043: htsp_process_event: [0/1/2, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jul 24 14:50:30.043: htsp_timer_stop2
Jul 24 14:50:30.043: [0/1/2] set signal state = 0x4 timestamp = 0
Jul 24 14:50:30.043: htsp_timer - 2000 msec
Jul 24 14:50:30.315: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Jul 24 14:50:32.043: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 24 14:50:32.043: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0100]
Seems like there is no service on the line
Have it tested using a regular phone.
Tested that line (0/1/2) using an old telephone and it has a dial tone to and are able to dial out OK. Also calls placed to the number on that port are answered by the CME just fine.
So is it still possible that the phone line is flaky (or borderline) or possible a bad FXO card?
Thanks for the help so far!
Try updating IOS and check again.
Also try swapping lines, does problem stay with line, or port ?
OK so I had some one try to make outgoing calls and it looks like that "power denial detected" happens on more ports. Have not moved around the lines yet, but getting dial tone and able to dial with a standard phone from all 3 lines.
Version 12.4(24)T6  (as it was recommended by Cisco), though we can upgrade just afraid we may break something else..
cisco#sh voice port summary | inc fxo
Jul 25 16:36:16.709: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:36:16.709: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:36  orig called=
Jul 25 16:36:16.725: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:36:17.429: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:36:17.817: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:36:18.157: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:36:18.381: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:36:18.729: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:36:19.097: htsp_digit_ready(50/0/22.1): digit = 7
Jul 25 16:36:19.389: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:36:19.657: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:36:19.889: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:36:20.165: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:36:20.409: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:36:20.657: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:36:20.665: htsp_timer_stop3
Jul 25 16:36:20.669: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jul 25 16:36:20.669: [50/0/22.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jul 25 16:36:20.669: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 25 16:36:20.673: [0/1/0] set signal state = 0xC timestamp = 0
Jul 25 16:36:20.673: htsp_timer - 1300 msec
Jul 25 16:36:20.921: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jul 25 16:36:20.925: htsp_timer2 - 1000 msec
Jul 25 16:36:20.925: htsp_timer_stop
Jul 25 16:36:21.925: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Jul 25 16:36:21.925: htsp_timer_stop
Jul 25 16:36:21.925: htsp_timer_stop2
Jul 25 16:36:21.925: [0/1/0] set signal state = 0x4 timestamp = 0
Jul 25 16:36:21.929: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Jul 25 16:36:25.913: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:36:25.913: htsp_timer - 10 msec
Jul 25 16:36:25.925: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
Jul 25 16:36:25.925: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
Jul 25 16:36:25.925: htsp_timer_stop
Jul 25 16:36:25.925: [50/0/22.1] set signal state = 0x4 timestamp = 0
Jul 25 16:36:30.505: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:36:30.505: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:36  orig called=
Jul 25 16:36:30.513: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:36:34.941: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:36:34.945: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:36:34.945: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:36:34.945: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:36:34.945: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:36:34.945: htsp_digit_ready(50/0/22.1): digit = 7
Jul 25 16:36:34.945: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:36:34.945: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:36:34.949: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:36:34.965: htsp_timer_stop3
Jul 25 16:36:34.965: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jul 25 16:36:34.965: [50/0/22.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jul 25 16:36:34.969: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 25 16:36:34.969: [0/1/1] set signal state = 0xC timestamp = 0
Jul 25 16:36:34.969: htsp_timer - 1300 msec
Jul 25 16:36:35.317: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jul 25 16:36:35.317: htsp_timer2 - 1000 msec
Jul 25 16:36:35.317: htsp_timer_stop
Jul 25 16:36:35.493: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0100]fxols_disc_clear
Jul 25 16:36:35.493: htsp_timer_stop2
Jul 25 16:36:35.493: htsp_timer - 1300 msec
Jul 25 16:36:36.793: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
Jul 25 16:36:40.041: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
Jul 25 16:36:40.041: htsp_timer - 350 msec
Jul 25 16:36:40.045: htsp_call_bridged invoked
Jul 25 16:36:40.045: htsp_call_bridged invokedhtsp_progress_notifyhtsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 0
Jul 25 16:36:40.053: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CALLERID_WAITING]
Jul 25 16:36:40.053: efxs_callerid_update
Jul 25 16:36:40.053: efxs_callerid_update process caller_id_string
Jul 25 16:36:40.053: efxs_callerid_update process caller_id_string OK
Jul 25 16:36:40.053: efxs_callerid_update number= [16307680431] name= []
Jul 25 16:36:40.053: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]efxs_offhook_cutthru
Jul 25 16:36:40.053: [50/0/22.1] set signal state = 0x7 timestamp = 0
Jul 25 16:36:40.057: htsp_process_event: [0/1/1, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
Jul 25 16:36:40.057: htsp_timer_stop htsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 1
Jul 25 16:36:40.061: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CONNECT]efxs_offhook_connect
Jul 25 16:36:40.061: [50/0/22.1] set signal state = 0x6 timestamp = 0
Jul 25 16:36:40.061: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_CALLERID_WAITING]
Jul 25 16:36:40.061: efxs_callerid_update
Jul 25 16:36:40.061: efxs_callerid_update process caller_id_string
Jul 25 16:36:40.061: efxs_callerid_update process caller_id_string OK
Jul 25 16:36:40.061: efxs_callerid_update number= [8154161500] name= []
Jul 25 16:36:43.057: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:36:43.057: htsp_timer - 10 msec
Jul 25 16:36:43.069: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_EVENT_TIMER]efxs_connect_wait_release_req
Jul 25 16:36:43.069: htsp_timer_stop
Jul 25 16:36:43.073: htsp_timer_stop3
Jul 25 16:36:43.077: htsp_process_event: [50/0/22.1, EFXS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ]efxs_waitrls_req_rlshtsp_report_onhook_sig
Jul 25 16:36:43.089: htsp_process_event: [0/1/1, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jul 25 16:36:43.089: htsp_timer_stop
Jul 25 16:36:43.089: htsp_timer_stop2
Jul 25 16:36:43.089: htsp_timer_stop3
Jul 25 16:36:43.089: [0/1/1] set signal state = 0x4 timestamp = 0
Jul 25 16:36:43.089: htsp_timer - 2000 msec
Jul 25 16:36:45.089: htsp_process_event: [0/1/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 25 16:36:45.089: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Jul 25 16:36:46.865: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:36:46.865: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:36  orig called=
Jul 25 16:36:46.877: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:36:47.741: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:36:48.169: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:36:48.569: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:36:48.729: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:36:49.101: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:36:49.397: htsp_digit_ready(50/0/22.1): digit = 7
Jul 25 16:36:49.729: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:36:50.025: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:36:50.273: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:36:50.637: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:36:50.937: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:36:51.245: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:36:51.253: htsp_timer_stop3
Jul 25 16:36:51.257: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jul 25 16:36:51.257: [50/0/22.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jul 25 16:36:51.257: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 25 16:36:51.257: [0/1/2] set signal state = 0xC timestamp = 0
Jul 25 16:36:51.257: htsp_timer - 1300 msec
Jul 25 16:36:51.529: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
Jul 25 16:36:51.529: htsp_timer_stop2
Jul 25 16:36:51.529: htsp_timer - 1300 msec
Jul 25 16:36:51.613: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jul 25 16:36:51.613: htsp_timer2 - 1000 msec
Jul 25 16:36:51.613: htsp_timer_stop
Jul 25 16:36:51.825: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
Jul 25 16:36:51.825: htsp_timer_stop2
Jul 25 16:36:51.825: htsp_timer - 1300 msec
Jul 25 16:36:53.125: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
Jul 25 16:36:56.373: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
Jul 25 16:36:56.373: htsp_timer - 350 msec
Jul 25 16:36:56.377: htsp_call_bridged invoked
Jul 25 16:36:56.377: htsp_call_bridged invokedhtsp_progress_notifyhtsp_call_feature:feature 25
Jul 25 16:36:56.385: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CALLERID_WAITING]
Jul 25 16:36:56.385: efxs_callerid_update
Jul 25 16:36:56.385: efxs_callerid_update process caller_id_string
Jul 25 16:36:56.385: efxs_callerid_update process caller_id_string OK
Jul 25 16:36:56.385: efxs_callerid_update number= [16307680431] name= []
Jul 25 16:36:56.385: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]efxs_offhook_cutthru
Jul 25 16:36:56.385: [50/0/22.1] set signal state = 0x7 timestamp = 0
Jul 25 16:36:56.389: htsp_process_event: [0/1/2, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
Jul 25 16:36:56.389: htsp_timer_stop htsp_call_feature:feature 25
Jul 25 16:36:56.393: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CONNECT]efxs_offhook_connect
Jul 25 16:36:56.393: [50/0/22.1] set signal state = 0x6 timestamp = 0
Jul 25 16:36:56.393: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_CALLERID_WAITING]
Jul 25 16:36:56.393: efxs_callerid_update
Jul 25 16:36:56.393: efxs_callerid_update process caller_id_string
Jul 25 16:36:56.393: efxs_callerid_update process caller_id_string OK
Jul 25 16:36:56.393: efxs_callerid_update number= [8154161502] name= []
Jul 25 16:36:59.505: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:36:59.505: htsp_timer - 10 msec
Jul 25 16:36:59.517: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_EVENT_TIMER]efxs_connect_wait_release_req
Jul 25 16:36:59.517: htsp_timer_stop
Jul 25 16:36:59.521: htsp_timer_stop3
Jul 25 16:36:59.525: htsp_process_event: [50/0/22.1, EFXS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ]efxs_waitrls_req_rlshtsp_report_onhook_sig
Jul 25 16:36:59.541: htsp_process_event: [0/1/2, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jul 25 16:36:59.541: htsp_timer_stop
Jul 25 16:36:59.541: htsp_timer_stop2
Jul 25 16:36:59.541: htsp_timer_stop3
Jul 25 16:36:59.541: [0/1/2] set signal state = 0x4 timestamp = 0
Jul 25 16:36:59.541: htsp_timer - 2000 msec
Jul 25 16:36:59.810: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Jul 25 16:37:00.174: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:37:00.174: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:37  orig called=
Jul 25 16:37:00.182: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:37:00.830: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:37:01.174: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:01.498: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:37:01.542: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 25 16:37:01.542: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0100]
Jul 25 16:37:01.658: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:37:02.034: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:02.334: htsp_digit_ready(50/0/22.1): digit = 7
Jul 25 16:37:02.646: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:37:02.926: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:37:03.166: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:03.462: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:37:03.758: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:37:04.010: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:04.018: htsp_timer_stop3
Jul 25 16:37:04.018: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jul 25 16:37:04.018: [50/0/22.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jul 25 16:37:04.022: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 25 16:37:04.022: [0/1/0] set signal state = 0xC timestamp = 0
Jul 25 16:37:04.022: htsp_timer - 1300 msec
Jul 25 16:37:04.274: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jul 25 16:37:04.274: htsp_timer2 - 1000 msec
Jul 25 16:37:04.274: htsp_timer_stop
Jul 25 16:37:05.274: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Jul 25 16:37:05.274: htsp_timer_stop
Jul 25 16:37:05.274: htsp_timer_stop2
Jul 25 16:37:05.274: [0/1/0] set signal state = 0x4 timestamp = 0
Jul 25 16:37:05.278: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Jul 25 16:37:09.406: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:37:09.406: htsp_timer - 10 msec
Jul 25 16:37:09.418: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
Jul 25 16:37:09.418: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
Jul 25 16:37:09.418: htsp_timer_stop
Jul 25 16:37:09.418: [50/0/22.1] set signal state = 0x4 timestamp = 0
Jul 25 16:37:10.374: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:37:10.374: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:37  orig called=
Jul 25 16:37:10.382: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:37:11.090: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:37:11.382: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:11.702: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:37:11.914: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:37:12.314: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:12.630: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:37:12.926: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:13.190: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:37:13.394: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:13.742: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:14.014: htsp_digit_ready(50/0/22.1): digit = 7
Jul 25 16:37:14.282: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:14.290: htsp_timer_stop3
Jul 25 16:37:14.290: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jul 25 16:37:14.290: [50/0/22.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jul 25 16:37:14.294: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 25 16:37:14.294: [0/1/1] set signal state = 0xC timestamp = 0
Jul 25 16:37:14.294: htsp_timer - 1300 msec
Jul 25 16:37:14.814: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jul 25 16:37:14.814: htsp_timer2 - 1000 msec
Jul 25 16:37:14.814: htsp_timer_stop
Jul 25 16:37:14.994: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0100]fxols_disc_clear
Jul 25 16:37:14.994: htsp_timer_stop2
Jul 25 16:37:14.994: htsp_timer - 1300 msec
Jul 25 16:37:16.294: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
Jul 25 16:37:19.542: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
Jul 25 16:37:19.542: htsp_timer - 350 msec
Jul 25 16:37:19.546: htsp_call_bridged invoked
Jul 25 16:37:19.546: htsp_call_bridged invokedhtsp_progress_notifyhtsp_call_feature:feature 25
Jul 25 16:37:19.554: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CALLERID_WAITING]
Jul 25 16:37:19.554: efxs_callerid_update
Jul 25 16:37:19.554: efxs_callerid_update process caller_id_string
Jul 25 16:37:19.554: efxs_callerid_update process caller_id_string OK
Jul 25 16:37:19.554: efxs_callerid_update number= [16304041071] name= []
Jul 25 16:37:19.554: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]efxs_offhook_cutthru
Jul 25 16:37:19.554: [50/0/22.1] set signal state = 0x7 timestamp = 0
Jul 25 16:37:19.558: htsp_process_event: [0/1/1, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
Jul 25 16:37:19.558: htsp_timer_stop htsp_call_feature:feature 25
Jul 25 16:37:19.562: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CONNECT]efxs_offhook_connect
Jul 25 16:37:19.562: [50/0/22.1] set signal state = 0x6 timestamp = 0
Jul 25 16:37:19.562: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_CALLERID_WAITING]
Jul 25 16:37:19.562: efxs_callerid_update
Jul 25 16:37:19.562: efxs_callerid_update process caller_id_string
Jul 25 16:37:19.562: efxs_callerid_update process caller_id_string OK
Jul 25 16:37:19.562: efxs_callerid_update number= [8154161500] name= []
Jul 25 16:37:21.238: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:37:21.238: htsp_timer - 10 msec
Jul 25 16:37:21.250: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_EVENT_TIMER]efxs_connect_wait_release_req
Jul 25 16:37:21.250: htsp_timer_stop
Jul 25 16:37:21.254: htsp_timer_stop3
Jul 25 16:37:21.258: htsp_process_event: [50/0/22.1, EFXS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ]efxs_waitrls_req_rlshtsp_report_onhook_sig
Jul 25 16:37:21.270: htsp_process_event: [0/1/1, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jul 25 16:37:21.270: htsp_timer_stop
Jul 25 16:37:21.270: htsp_timer_stop2
Jul 25 16:37:21.270: htsp_timer_stop3
Jul 25 16:37:21.270: [0/1/1] set signal state = 0x4 timestamp = 0
Jul 25 16:37:21.270: htsp_timer - 2000 msec
Jul 25 16:37:22.034: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:37:22.034: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:37  orig called=
Jul 25 16:37:22.046: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:37:22.874: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:37:23.190: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:23.270: htsp_process_event: [0/1/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 25 16:37:23.270: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Jul 25 16:37:23.494: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:37:23.662: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:37:24.014: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:24.446: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:37:24.718: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:24.934: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:37:25.150: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:25.466: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:25.718: htsp_digit_ready(50/0/22.1): digit = 7
Jul 25 16:37:25.970: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:25.978: htsp_timer_stop3
Jul 25 16:37:25.978: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jul 25 16:37:25.978: [50/0/22.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jul 25 16:37:25.982: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 25 16:37:25.982: [0/1/2] set signal state = 0xC timestamp = 0
Jul 25 16:37:25.982: htsp_timer - 1300 msec
Jul 25 16:37:26.254: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
Jul 25 16:37:26.254: htsp_timer_stop2
Jul 25 16:37:26.254: htsp_timer - 1300 msec
Jul 25 16:37:26.414: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jul 25 16:37:26.414: htsp_timer2 - 1000 msec
Jul 25 16:37:26.414: htsp_timer_stop
Jul 25 16:37:26.626: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
Jul 25 16:37:26.626: htsp_timer_stop2
Jul 25 16:37:26.626: htsp_timer - 1300 msec
Jul 25 16:37:27.926: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
Jul 25 16:37:31.174: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
Jul 25 16:37:31.174: htsp_timer - 350 msec
Jul 25 16:37:31.178: htsp_call_bridged invoked
Jul 25 16:37:31.178: htsp_call_bridged invokedhtsp_progress_notifyhtsp_call_feature:feature 25
Jul 25 16:37:31.182: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CALLERID_WAITING]
Jul 25 16:37:31.182: efxs_callerid_update
Jul 25 16:37:31.186: efxs_callerid_update process caller_id_string
Jul 25 16:37:31.186: efxs_callerid_update process caller_id_string OK
Jul 25 16:37:31.186: efxs_callerid_update number= [16304041071] name= []
Jul 25 16:37:31.186: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]efxs_offhook_cutthru
Jul 25 16:37:31.186: [50/0/22.1] set signal state = 0x7 timestamp = 0
Jul 25 16:37:31.190: htsp_process_event: [0/1/2, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
Jul 25 16:37:31.190: htsp_timer_stop htsp_call_feature:feature 25
Jul 25 16:37:31.194: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_CONNECT]efxs_offhook_connect
Jul 25 16:37:31.194: [50/0/22.1] set signal state = 0x6 timestamp = 0
Jul 25 16:37:31.194: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_CALLERID_WAITING]
Jul 25 16:37:31.194: efxs_callerid_update
Jul 25 16:37:31.194: efxs_callerid_update process caller_id_string
Jul 25 16:37:31.194: efxs_callerid_update process caller_id_string OK
Jul 25 16:37:31.194: efxs_callerid_update number= [8154161502] name= []
Jul 25 16:37:33.034: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:37:33.038: htsp_timer - 10 msec
Jul 25 16:37:33.050: htsp_process_event: [50/0/22.1, EFXS_CONNECT, E_HTSP_EVENT_TIMER]efxs_connect_wait_release_req
Jul 25 16:37:33.050: htsp_timer_stop
Jul 25 16:37:33.054: htsp_timer_stop3
Jul 25 16:37:33.058: htsp_process_event: [50/0/22.1, EFXS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ]efxs_waitrls_req_rlshtsp_report_onhook_sig
Jul 25 16:37:33.070: htsp_process_event: [0/1/2, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jul 25 16:37:33.070: htsp_timer_stop
Jul 25 16:37:33.070: htsp_timer_stop2
Jul 25 16:37:33.070: htsp_timer_stop3
Jul 25 16:37:33.070: [0/1/2] set signal state = 0x4 timestamp = 0
Jul 25 16:37:33.070: htsp_timer - 2000 msec
Jul 25 16:37:33.342: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Jul 25 16:37:33.890: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:37:33.890: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:37  orig called=
Jul 25 16:37:33.898: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:37:34.574: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:37:34.882: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:35.070: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 25 16:37:35.070: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0100]
Jul 25 16:37:35.186: htsp_digit_ready(50/0/22.1): digit = 6
Jul 25 16:37:35.362: htsp_digit_ready(50/0/22.1): digit = 3
Jul 25 16:37:36.234: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:36.526: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:37:36.802: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:37.070: htsp_digit_ready(50/0/22.1): digit = 4
Jul 25 16:37:37.290: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:37.618: htsp_digit_ready(50/0/22.1): digit = 0
Jul 25 16:37:37.846: htsp_digit_ready(50/0/22.1): digit = 7
Jul 25 16:37:38.098: htsp_digit_ready(50/0/22.1): digit = 1
Jul 25 16:37:38.102: htsp_timer_stop3
Jul 25 16:37:38.106: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jul 25 16:37:38.106: [50/0/22.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jul 25 16:37:38.106: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jul 25 16:37:38.106: [0/1/0] set signal state = 0xC timestamp = 0
Jul 25 16:37:38.110: htsp_timer - 1300 msec
Jul 25 16:37:38.358: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jul 25 16:37:38.358: htsp_timer2 - 1000 msec
Jul 25 16:37:38.358: htsp_timer_stop
Jul 25 16:37:39.358: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Jul 25 16:37:39.358: htsp_timer_stop
Jul 25 16:37:39.358: htsp_timer_stop2
Jul 25 16:37:39.358: [0/1/0] set signal state = 0x4 timestamp = 0
Jul 25 16:37:39.362: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Jul 25 16:37:40.702: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:37:40.702: htsp_timer - 10 msec
Jul 25 16:37:40.714: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
Jul 25 16:37:40.714: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
Jul 25 16:37:40.714: htsp_timer_stop
Jul 25 16:37:40.714: [50/0/22.1] set signal state = 0x4 timestamp = 0
Jul 25 16:37:41.354: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jul 25 16:37:41.354: [50/0/22.1] get_local_station_id calling num=201 calling name=Mike calling time=07/25 11:37  orig called=
Jul 25 16:37:41.362: htsp_process_event: [50/0/22.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jul 25 16:37:42.122: htsp_digit_ready(50/0/22.1): digit = 8
Jul 25 16:37:43.294: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
Jul 25 16:37:43.294: htsp_timer - 10 msec
Jul 25 16:37:43.306: htsp_process_event: [50/0/22.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
Jul 25 16:37:43.306: htsp_process_event: [50/0/22.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
Jul 25 16:37:43.306: htsp_timer_stop
Jul 25 16:37:43.306: [50/0/22.1] set signal state = 0x4 timestamp = 0
Jul 25 16:39:49.340: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Jul 25 16:39:49.340: htsp_timer - 125 msec
Jul 25 16:39:49.468: htsp_process_event: [0/1/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Jul 25 16:39:49.468: htsp_timer - 10000 msec
Jul 25 16:39:49.468: htsp_timer3 - 5600 msec
Jul 25 16:39:49.468: [0/1/1] htsp_start_caller_id_rx:BELLCORE
Jul 25 16:39:49.468: htsp_start_caller_id_rx create dsp_stream_manager
Jul 25 16:39:49.468: [0/1/1] htsp_dsm_create_success  returns 1
Jul 25 16:39:51.272: htsp_process_event: [0/1/1, FXOLS_RINGING, E_DSP_SIG_0110]
Jul 25 16:39:51.416: htsp_process_event: [0/1/1, FXOLS_RINGING, E_DSP_SIG_0100]
Jul 25 16:39:51.416: fxols_ringing_not
Jul 25 16:39:51.416: htsp_timer_stop
Jul 25 16:39:51.416: htsp_timer - 10000 msec
Jul 25 16:39:52.720: [0/1/1] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATURE_SM_CALLERID_RX
Jul 25 16:39:52.720: htsp_process_event: [0/1/1, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
Jul 25 16:39:52.720: htsp_timer_stop
Jul 25 16:39:52.720: htsp_timer_stop3
Jul 25 16:39:52.720: [0/1/1] htsp_stop_caller_id_rx. message length 42htsp_setup_ind
Jul 25 16:39:52.720: [0/1/1] get_fxo_caller_id:Caller ID received. Message type=128 length=42 checksum=57
Jul 25 16:39:52.720: [0/1/1] Caller ID String 80 27 01 08 30 37 32 35 31 31 33 39 02 0A 36 33 30 34 30 34 31 30 37 31 07 0F 57 49 52 45 4C 45 53 53 20 43 41 4C 4C 45 52 57
Jul 25 16:39:52.720: [0/1/1] get_fxo_caller_id calling num=6304041071 calling name=WIRELESS CALLER calling time=07/25 11:39
Jul 25 16:39:52.720: fxols_callerid_done: call being answered
Jul 25 16:39:52.728: htsp_process_event: [0/1/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Jul 25 16:39:52.728: fxols_wait_setup_ack:
Jul 25 16:39:52.728: htsp_timer - 6000 msec
Jul 25 16:39:52.736: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Jul 25 16:39:52.740: [0/1/1] htsp_dsm_close_donehtsp_alert_notify
Jul 25 16:39:52.772: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Jul 25 16:39:52.812: htsp_call_bridged invoked
Jul 25 16:39:52.820: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
Jul 25 16:39:52.820: [0/1/1] set signal state = 0xC timestamp = 0
Jul 25 16:39:52.820: htsp_timer_stop
Jul 25 16:39:52.820: htsp_process_event: [0/1/1, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
Jul 25 16:39:53.460: htsp_process_event: [0/1/1, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
Jul 25 16:39:53.460: htsp_timer2 - 350 msec
Jul 25 16:39:53.812: htsp_process_event: [0/1/1, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
Jul 25 16:39:53.812: htsp_timer_stop
Jul 25 16:39:53.812: htsp_timer_stop2
Jul 25 16:39:53.812: htsp_timer_stop3
Jul 25 16:39:53.816: htsp_timer_stop3
Jul 25 16:39:53.840: htsp_process_event: [0/1/1, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jul 25 16:39:53.840: htsp_timer_stop
Jul 25 16:39:53.840: htsp_timer_stop2
Jul 25 16:39:53.840: htsp_timer_stop3
Jul 25 16:39:53.840: [0/1/1] set signal state = 0x4 timestamp = 0
Jul 25 16:39:53.844: htsp_timer - 2000 msec
Jul 25 16:39:55.844: htsp_process_event: [0/1/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 25 16:39:55.844: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Jul 25 16:40:39.429: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Jul 25 16:40:39.429: htsp_timer - 125 msec
Jul 25 16:40:39.557: htsp_process_event: [0/1/2, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Jul 25 16:40:39.557: htsp_timer - 10000 msec
Jul 25 16:40:39.557: htsp_timer3 - 5600 msec
Jul 25 16:40:39.557: [0/1/2] htsp_start_caller_id_rx:BELLCORE
Jul 25 16:40:39.557: htsp_start_caller_id_rx create dsp_stream_manager
Jul 25 16:40:39.557: [0/1/2] htsp_dsm_create_success  returns 1
Jul 25 16:40:41.529: htsp_process_event: [0/1/2, FXOLS_RINGING, E_DSP_SIG_0100]
Jul 25 16:40:41.529: fxols_ringing_not
Jul 25 16:40:41.529: htsp_timer_stop
Jul 25 16:40:41.529: htsp_timer - 10000 msec
Jul 25 16:40:42.729: [0/1/2] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATURE_SM_CALLERID_RX
Jul 25 16:40:42.729: htsp_process_event: [0/1/2, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
Jul 25 16:40:42.729: htsp_timer_stop
Jul 25 16:40:42.729: htsp_timer_stop3
Jul 25 16:40:42.729: [0/1/2] htsp_stop_caller_id_rx. message length 42htsp_setup_ind
Jul 25 16:40:42.729: [0/1/2] get_fxo_caller_id:Caller ID received. Message type=128 length=42 checksum=5F
Jul 25 16:40:42.729: [0/1/2] Caller ID String 80 27 01 08 30 37 32 35 31 31 34 30 02 0A 36 33 30 34 30 34 31 30 37 31 07 0F 57 49 52 45 4C 45 53 53 20 43 41 4C 4C 45 52 5F
Jul 25 16:40:42.729: [0/1/2] get_fxo_caller_id calling num=6304041071 calling name=WIRELESS CALLER calling time=07/25 11:40
Jul 25 16:40:42.729: fxols_callerid_done: call being answered
Jul 25 16:40:42.737: htsp_process_event: [0/1/2, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Jul 25 16:40:42.737: fxols_wait_setup_ack:
Jul 25 16:40:42.737: htsp_timer - 6000 msec
Jul 25 16:40:42.749: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Jul 25 16:40:42.749: [0/1/2] htsp_dsm_close_donehtsp_alert_notify
Jul 25 16:40:42.821: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Jul 25 16:40:42.865: htsp_call_bridged invoked
Jul 25 16:40:42.869: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_VOICE_CUT_THROUGH]fxols_proc_voice
Jul 25 16:40:42.873: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
Jul 25 16:40:42.873: [0/1/2] set signal state = 0xC timestamp = 0
Jul 25 16:40:42.873: htsp_timer_stop
Jul 25 16:40:43.145: htsp_process_event: [0/1/2, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
Jul 25 16:40:43.145: htsp_timer_stop2
Jul 25 16:41:07.762: htsp_digit_ready(0/1/2): digit = 2
Jul 25 16:41:10.870: htsp_timer_stop3
Jul 25 16:41:10.894: htsp_process_event: [0/1/2, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jul 25 16:41:10.894: htsp_timer_stop
Jul 25 16:41:10.894: htsp_timer_stop2
Jul 25 16:41:10.894: htsp_timer_stop3
Jul 25 16:41:10.894: [0/1/2] set signal state = 0x4 timestamp = 0
Jul 25 16:41:10.894: htsp_timer - 2000 msec
Jul 25 16:41:11.166: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Jul 25 16:41:12.894: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 25 16:41:12.894: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0100]
As you said, it might be a marginal line.
If you update, you might not solve, but you gain lots of features and usability, nothing will break.
