Warning message
Urgent help needed for VoIP Natting on 1841
Jul 23rd, 2012
ip http server
ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list 1 interface FastEthernet0/0/0 overload
ip nat inside source list 101 interface FastEthernet0/0/0 overload
ip nat inside source list 103 interface FastEthernet0/0/0 overload
ip nat inside source static udp 192.168.1.154 5060 66.128.121.27 5060 extendable
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark RDP To Domain Server
access-list 70 permit 192.168.1.0 0.0.0.255
access-list 101 permit tcp any any eq 4004
access-list 102 permit ip any any
access-list 102 deny   tcp any any eq 22
access-list 103 remark CCP_ACL Category=18
access-list 103 permit udp any any range 10000 20000
access-list 103 permit tcp any any eq 5222 established
access-list 103 permit udp any any eq 5060
access-list 110 permit udp any any range 10000 20000
Ok  I am at a loss  Probably something dumb  but i cant get sip signaling back on port 5060   Audio is good tho.  Any idea would be urgently welcome as the voice pbx is down.
paolo bevilacqua Mon, 07/23/2012 - 08:34
  • Hall of Fame,
    Founding Member
First the access list used seems to be wrong, establisehd is not used in NAT ACL.
Second, by disabling SIP-ALG, things are unlikely to work
Then, can you explain in other words what is the problem that  you are xpereincing?
Finally, if you need guaranteed, time bound support get a smartnet contract, as this is a free forum.
starpoint09 Mon, 07/23/2012 - 09:06
5222 establied is for a data stream  that goes between an IM system with teh PBX
Not Getting Sip Signalling back from the carrier.
paolo bevilacqua Mon, 07/23/2012 - 13:13
  • Hall of Fame,
    Founding Member
That is very possible since you disabled sip-alg, you're sending out private IP address and so thye are not responding.
Related Content
