Warning message
can we use vpn on ipad
Answered Question
Jul 23rd, 2012
                   HI, I just want to know can we use vpn using ipad.? if can what are the steps to do that..
Tino
Correct Answer by Tarik Admani about 5 years 3 weeks ago
Tino,
Here is the configuation guide of the anyconnect for the apple ios devices, there it should have the requirements (hardware and licensing) in order to get this to work.
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect24/ios4.2-user/guide/ipad-ugac-ios4.2.html
Let me know if you need anything else,
Tarik Admani
*Please rate helpful posts*
Overall Rating: 5 (1 ratings)
Correct Answer
Tarik Admani Mon, 07/23/2012 - 10:03
  • Green, 3000 points or more
Tino,
Tarik Admani
tinmk Mon, 07/23/2012 - 10:40
Hi thanks for the link. So do we need to do any configuration on Cisco ASA for this or all current vpn user can connect it through the ipad with the normal username and password.
Tarik Admani Mon, 07/23/2012 - 10:46
Tino,
You will have to configure the ASA in order to accept/authorize the vpn connection from the anyconnect users, you will have to check your licenses as well. Here is the configuration guide on how to set that up.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/svc.html
Tarik Admani
