Warning message
reconfig of 3750 g
Answered Question
Jul 23rd, 2012
Can someone explain how to access (to reconfig) a 3750g that was configured to use a radius server for authentication?
We just installed a new stack and will be using the old switches for other tasks. It continues to show the radius as not responding, but as being marked alive. Thanks.
Correct Answer by Richard Burts about 5 years 3 weeks ago
Chris
It sounds like you are looking for how to do password recovery on the switch so that you can bypass the existing config. Can you confirm that this is what you are looking for?
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Mon, 07/23/2012 - 19:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chris
Rick
Ccrawford13 Tue, 07/24/2012 - 07:11
You were correct. The loop while booting was irregular, and I thought I could "break in" without using recovery. I was wrong.
Thanks for the response!
Richard Burts Tue, 07/24/2012 - 08:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Chris
I am glad that you got it worked out and that my response was helpful. Thank you for using the rating system to indicate that the question was answered. It makes the forum more useful when people can read a question and can know that an answer was found. Your marking has contributed to this process.
Rick
Related Content
