[Trend Micro Ios content filtering] parameter-type command under policy map not available
Jul 23rd, 2012
Hi, all:
I'm trying to configure TrendMicro IOS content filtering. I have this working on a separate box, running 15.1.
On this particular testbed, I have a 2900 running:
System image file is "flash0:c2900-universalk9-mz.SPA.152-3.T1.bin"
And the following licensing:
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          datak9        Permanent      datak9
CUBE_GOLD_MEX#show ip trm subscription status
       Package Name:  Security & Productivity (Trial)
             Status:  Active
Status Update Time:  18:02:51 CST Mon Jul 23 2012
    Expiration-Date:  Mon Aug 20 02:00:00 2012
    Last Req Status:  Processed response successfully
Last Req Sent Time:  18:02:51 CST Mon Jul 23 2012
CUBE_GOLD_MEX#
Also, I have the following config lines on it:
ip host trps.trendmicro.com 216.104.8.100
ip name-server 4.2.2.2
ip cef
parameter-map type urlfpolicy trend tm-pmap
allow-mode on
[snip]
parameter-map type trend-global trend-glob-map
class-map type inspect match-all http-imap
match protocol http
class-map type urlfilter trend match-any drop-category
match url category Abortion
match url category Activist-Groups
match url category Adult-Mature-Content
match url reputation ADWARE
match url reputation DIALER
match url reputation DISEASE-VECTOR
match url reputation HACKING
match url reputation PASSWORD-CRACKING-APPLICATIONS
match url reputation PHISHING
match url reputation POTENTIALLY-MALICIOUS-SOFTWARE
match url reputation SPYWARE
match url reputation VIRUS-ACCOMPLICE
policy-map type inspect urlfilter trend-policy
class type urlfilter trend drop-category
I have not been able to get to the good part of configuring the ZBF.
I've looked over several configuration examples and can't figure out what I'm doing wrong, since I'm not able to see the command 'parameter-map' under the 'policy-map urlfiltering'
XXXXXX(config)#policy-map type inspect urlfilter trend-policy
XXXXXX(config-pmap)#?
Policy-map configuration commands:
  class        policy criteria
  description  Policy-Map description
  exit         Exit from policy-map configuration mode
  no           Negate or set default values of a command
I thought it might be an issue with version 15.2.3, but according to configuration guides, commands are the same.
Can anyone provide some assistance?
TIA.
c.
tpeckman Wed, 08/01/2012 - 14:00
Hi Carlos,
I am having the same problem.  I have seen a few diffenent configuration examples and they all show adding the "parameter type urlfpolicy trend parm-map-name" command but it doesn't exist, at least in 15.2(3)T1 and I see it listed in the the IOS documentation for 15.2.  Maybe they forgot it :-)
I guess I will open a TAC case as I do not want to downgrade...
I will keep you posted if I find the answer.
Troy
Carlos A. Silva Thu, 08/02/2012 - 07:02
Thanks a lot, Troy. I cannot open a TT, so if you do open it, I'd really appreciate it if you let me know what they said.
We went back to 15.1. No other choice right now.
c.
tpeckman Thu, 08/02/2012 - 07:11
I opened a case yesterday and was told to downgrade to 15.1(4)M4 as there is a known issue with 15.2. I just finished booting with that code and the “parameter” command is back. I guess we will stick with this rev for a while.
Good luck.
Troy
