Warning message
Cisco Route map question
Jul 24th, 2012
I already have a route-map in place allowing traffic from 192.168.101.0/24 to use dual ISP, tracked using SLA.
I want a host behind to have a specific public IP, so I can connect too either public IP if one ISP fails.  I was thinking something like this but not sure how I speficify the specific public IP on each VLAN.
Do I need to "match interface" to an IP or something?
Access-list 200 permit ip 192.168.101.200 0.0.0.255 any
route-map CCTV_ISP1 permit 10
match ip address 200
match interface vlan3
route-map CCYV_ISP2 permit 10
match interface vlan2
ip nat inside source route-map CCTV_ISP1 interface Vlan2 overload
ip nat inside source route-map CCTV_ISP2 interface Vlan3 overload
normally if a single IP a static NAT
ip nat inside source static tcp 192.168.101.4 1723 x.x.x.x 8080 extendable if what I'm trying to replicate but allowing mapping from both when failover occurs
cadet alain Tue, 07/24/2012 - 07:29
  • Purple, 4500 points or more
just do another entry like this with the other public IP or external interface:
Regards.
Alain.
Related Content
