Cisco 7961G IP Phone with Astrerisk Server Issue
Jul 24th, 2012
I am having problem while connecting Cisco IP phone with Asterisk Server
Cisco 7961g IP Phone.
Version Using : SIP 41.9-2-3
Voip Server (Asterisk Server 1.6 Version)
192.168.0.135
I find so manythings but on wire shark also not coming any request.
Windows XP system :
192.168.0.195
Wireshark Log
3082    2028.725312    192.168.0.195    192.168.0.135    SIP    Request: SUBSCRIBE
sip:[email protected]
, in-dialog
3083    2028.726427    192.168.0.135    192.168.0.195    SIP    Status: 401 Unauthorized
3084    2028.827852    192.168.0.195    192.168.0.135    SIP    Request: SUBSCRIBE
, in-dialog
3085    2028.828698    192.168.0.135    192.168.0.195    SIP    Status: 200 OK
1469    184.752685    192.168.0.195    192.168.0.135    SIP    Request: SUBSCRIBE
, in-dialog
File <dialplan.xml> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:03:41.359]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1D:45:E8:A6:9C [23/07 11:11:41.875]
Previously allocated address 192.168.0.10 acked [23/07 11:11:41.875]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1D:45:E8:A6:9C [23/07 11:11:49.484]
Previously allocated address 192.168.0.10 acked [23/07 11:11:49.484]
Connection received from 192.168.0.10 on port 50657 [23/07 11:12:14.890]
Read request for file <CTLSEP001D45E8A69C.tlv>. Mode octet [23/07 11:12:14.890]
File <CTLSEP001D45E8A69C.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:14.890]
Connection received from 192.168.0.10 on port 50866 [23/07 11:12:15.015]
Read request for file <ITLSEP001D45E8A69C.tlv>. Mode octet [23/07 11:12:15.015]
File <ITLSEP001D45E8A69C.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:15.015]
Connection received from 192.168.0.10 on port 51212 [23/07 11:12:15.140]
Read request for file <ITLFile.tlv>. Mode octet [23/07 11:12:15.140]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:15.140]
Connection received from 192.168.0.10 on port 50804 [23/07 11:12:15.515]
Read request for file <SEP001D45E8A69C.cnf.xml>. Mode octet [23/07 11:12:15.515]
Using local port 2089 [23/07 11:12:15.515]
<SEP001D45E8A69C.cnf.xml>: sent 14 blks, 7120 bytes in 0 s. 0 blk resent [23/07 11:12:15.531]
Connection received from 192.168.0.10 on port 50713 [23/07 11:12:27.515]
Read request for file </mk-sip.jar>. Mode octet [23/07 11:12:27.515]
File <\mk-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:27.515]
Connection received from 192.168.0.10 on port 50382 [23/07 11:12:28.687]
Read request for file <US/g3-tones.xml>. Mode octet [23/07 11:12:28.687]
File <US\g3-tones.xml> : error 3 in system call CreateFile The system cannot find the path specified. [23/07 11:12:28.687]
Connection received from 192.168.0.10 on port 53157 [23/07 11:12:40.046]
Read request for file <dialplan.xml>. Mode octet [23/07 11:12:40.062]
File <dialplan.xml> : error 2 in system call CreateFile The system cannot find the file specified. [23/07 11:12:40.062]
ronpatel Tue, 07/24/2012 - 04:09
  • Blue, 1500 points or more
Cisco ip phone are not tested to run with third party application.
Ronak Patel
Rate helpful posts.
