Difference between Multimode Fiber Optics
Hi there,
I was wondering what is the difference between GLC-SX-MM and GLC-SX-MMD.
Cisco website says that MMD is with DOM, kindly help me understand what it is.
Ram
The difference between the two is the DOM functionality. DOM stands for Digital Optical Monitoring. Basically it's a function that allows network adminstrator determine the send/receive power, temperature, winning lotto number.
DOM is very, very helpful and I wouldn't purchase anything without one.
Hi Ram,
Digital diagnostics monitoring
Modern optical SFP transceivers support digital diagnostics monitoring (DDM) functions according to the industry-standard SFF-8472. This feature is also known as digital optical monitoring (DOM). This feature gives the end user the ability to monitor real-time parameters of the SFP, such as optical output power, optical input power, temperature, laser bias current, and transceiver supply voltage.
Nothing as far as i see it has some added advantage of digital diaganostics than the legacy model.
Please do rate for the helpful posts.
By
Karthik
