Warning message
cucm update from 7.1 .3 to 7.1.5
I want to update my CUCM 7.1.3  to 7.1.5     plz clear my some question
1 . is there any chance to call procesing down during the update?
2.  i want to install   CCMUpgdAsstInstall.4-3-13.exe but some probem showing is( error opening instalation log file.verify that the specified log file loaction exist and is writable) to update.
3. if possible plz step to proceed the update so that my existing setup no face any problem
Chris Deren Tue, 07/24/2012 - 09:40
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
1. Yes, during the upgrade the servers are rebooted, if you do one server at a time you can minimize the impact
2. What are you instaling this for if you are on version 7.1.3?
3. Have you read the install/upgrade doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html
HTH,
Chris
Chris Deren Tue, 07/24/2012 - 10:47
  • Hall of Fame,
The tool is only for Windows based CUCM i.e. 3.X, 4.X as described here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/assistant/up4310tl.html
You do not need it if you are already on 7.1.3 nor would it work as this is .exe that gets instaled on Windows CUCM servers.
HTH, please rate all useufl posts!
Chris
Related Content
